A fast, duplex A3 mono laser printer for workgroups, with a high paper capacity and network connectivity for easy office integration.
Duplex A3 mono laser
- Epson WorkForce AL-M8100DTN - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 26 kg
- Media Size Class
- A3/Ledger
- Max Media Size
- 297 x 900 mm
- Max Media Size (Custom)
- 297 mm x 900 mm
- Print Speed
- Up to 40 ppm - B/W , Up to 28 ppm - B/W duplex
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN
- Processor
- 600 MHz
- RAM Installed (Max)
- 1 GB (1 GB)
- Language Simulation
- PCL 3, PCL 5C, PostScript 3, PCL 6, PDF 1.7
- Media Type
- Envelopes, labels, plain paper, cards, recycled paper, thick paper
- Total Media Capacity
- 1100 sheets
- Media Handling
- 2x 500-sheet input trays, 100-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 220000 pages
- Networking
- Print server
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.6.8 or later, Windows 8, Microsoft Windows Server 2012 x64 Edition, Windows 8.1
- 49 cm x 41 cm x 45.1 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 1200 x 1200 dpi
- PostScript Support
- Included
- First Print Out Time B/W
- 9 sec
- Media Handling
- Processor
- 600 MHz
RAM
- 1 GB / 1 GB (max)
Media Handling
- Media Type
- Media Size Class
- A3/Ledger
- Max Media Size
- 297 x 900 mm
- 297 mm x 900 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), F4, 297 x 900 mm, 203 x 267 mm, 215.9 x 330.2 mm, 139.7 x 215.9 mm
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm)
- Media Weight
- 60 g/m² - 220 g/m²
- 1100 sheets
- Media Feeders
- 2 x automatic - 500 sheets , 1 x automatic - 100 sheets
- Max Media Capacity
- 2600 sheets
- Output Trays Capacity
- 500 sheets
Duty Cycle
- 220000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP, IPP, SLP
- IPsec, 802.1x
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
- Epson AcuBrite Toner
- EN55022, IEC 61000-4-11, IEC 61000-4-2, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, IEC 60950-1, IEC 60825-1, ISO/IEC 19752, ISO/IEC 19798, ISO/IEC 24734
- Power Device
- Power supply - internal
- Software Included
- EpsonNet Config
- OS Required
Environmental Standards
- ENERGY STAR
- 10 °C
- 32.5 °C
- 15 - 80%
- Sound Emission (Idle)
- 30 dBA
- Sound Emission (Operating)
- 51 dBA
- 49 cm
- 41 cm
- 45.1 cm
- 26 kg
