The Epson WorkForce AL-MX200DNF is network-ready for sharing across small workgroups, but can also be used on individual user desktops thanks to its compact size. It also features a retractable paper tray which, when the printer is not in use, can be folded away.
The Epson WorkForce AL-MX200DNF's toner cartridge is easy to replace. Users simply insert the cartridge into the toner slot and twist to connect. No mess, no hassle, no problem.
In addition, users can print and share from anywhere in the office, thanks to Epson's mobile printing app, Epson iPrint. This easy-to-use application allows workers to print wirelessly from smartphones and tablet PCs* .
Documents can be scanned straight to USB, ideal for quick document sharing or saving files to portable memory devices. In addition, documents can be scanned and sent directly to email accounts, ensuring important paper documents can be shared instantly to members of staff anywhere.
With the Epson WorkForce AL-MX200DNF, businesses can concentrate on their work, without any downtime, as its high-performance, user-friendly features offers great peace of mind and productivity.
- Epson WorkForce AL-MX200DNF - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- LED (monochrome)
- Monthly Duty Cycle (max)
- 30000 impressions
- Max Copying Speed
- Up to 20 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 30 ppm
- Max Printing Resolution
- Up to 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 1200 dpi
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper
- Standard Media Capacity
- 250 sheets
- Output Trays Capacity
- 125 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to network
- Power
- AC 230 V (50/60Hz)
- 42 cm x 39.8 cm x 36.5 cm
- 12 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- LED - monochrome
- 30000 impressions
- Display
- 4 lines
- Interface
- Standard Memory
- 256 MB 256 MB
- Max Supported Memory
- 256 MB 256 MB
Copying
- Max Copying Speed
- Up to 20 ppm
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 1200 dpi
- Up to 30 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3
- First Print Out Time B/W
- 7 sec
Scanning
- Optical Resolution
- 1200 x 1200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 99 station(s)
Document & Media Handling
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 125 sheets
- Input tray - 250 sheets - Legal (216 x 356 mm) , ADF - 50 sheets , Output tray - 125 sheets
- Speed Details
- Printing: up to 30 ppm - B/W , Copying: up to 20 ppm - B/W
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- Operating System Support
- MS Windows XP, Linux, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Apple Mac OS X 10.5.8 or later, Windows 8
- Software Included
- Drivers & Utilities
- Voltage Required
- 500 Watt
- Power Consumption Standby
- 55 Watt
- Power Consumption Sleep
- 8 Watt
- Warm-Up Time
- 45 sec
- First Copy Out Time B/W
- 20 sec
- Consumables Included
- 1 x toner cartridge (black)
- EN 61000-3-2, EN55022, EN 61000-3-3, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1
- ENERGY STAR Certified
- Limited warranty - 1 year - carry-in
- 42 cm
- 39.8 cm
- 36.5 cm
- 12 kg
- Shipping Width
- 51 cm
- Shipping Depth
- 55.4 cm
- Shipping Height
- 49.3 cm
- Shipping Weight
- 15 kg
- Sound Emission
- 25.5 dBA (idle) / 54.5 dBA (operating)
- 10 °C
- 32 °C
- 10 - 85%
Ink (1)
Epson AL-M200/MX200 Standard Capacity Toner Cartridge 2.5k | In Stock | £72.72 |
Other bundles (1)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
