Epson WorkForce AL-C300N 31ppm  A4  Colour Laser Printer
Quicklinx: BDVNWS00 Mfr#: C11CE09401BY
Fast, high-quality and low-cost printing
The AL-C300N delivers ISO print speeds of up to 31ppm, in both mono and colour¹. Prints are delivered at 1200 x 1200 dpi for high-quality results, and 1GB of RAM as standard saves time on repeated print jobs.
Easy to use and energy efficient
Its LCD screen makes it easy to control advanced functions. A high toner yield of up to 7,300 pages in black and 8,800 pages in colour² not only makes your supplies go further, but it also means less time is wasted changing supplies. A double pack of black toner is also available. Not only is the AL-C300N ENERGY STAR-qualified, it also has a very low power used of 1.3W when in deep sleep mode.
High durability
It has a duty cycle of up to 120,000 pages³, so businesses can be confident that their investment in the Epson range is a sound one.
Advanced connectivity, integration and security
PDL printer emulations including PCL6, PostScript 3 and PDF 1.7, along with the advanced IPv6 protocol and gigabit Ethernet support, make this printer ideal for business environments. Advanced IPSec and SSL support help improve security when printing sensitive materials, and print securely and confidentially with Email Print for Enterprise compatiblity4.
  • Fast A4 colour laser
    A compact and affordable A4 colour laser printer with easy network integration, delivering fast and high-quality results.
Epson AL-C300N - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
27.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 31 ppm - B/W , Up to 31 ppm - colour
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
USB 2.0, Gigabit LAN, USB host
750 MHz
RAM Installed (Max)
1 GB (1 GB)
Language Simulation
PCL 5E, PCL 5C, PostScript 3, PCL 6, PDF 1.7
Media Type
Envelopes, plain paper
Total Media Capacity
350 sheets
Media Handling
100-sheet multipurpose tray, 250-sheet input tray
Monthly Duty Cycle (max)
120000 pages
Print server
Linux, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition, Apple MacOS X 10.6.8 or later, Windows 8, Microsoft Windows Server 2012 x64 Edition, Microsoft Windows Server 2012 R2, Windows 8.1
1-year warranty
44.4 cm x 54.4 cm x 35 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
1200 x 1200 dpi
1200 x 1200 dpi
First Print Out Time B/W
12 sec
Language Simulation
Media Handling
750 MHz
RAM
RAM Installed (Max)
1 GB / 1 GB (max)
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), F4
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm)
Media Weight
60 g/m² - 210 g/m²
350 sheets
Max Media Capacity
850 sheets
Output Trays Capacity
200 sheets
Duty Cycle
120000 pages
Print server
Remote Management Protocol
SNMP, IPP, HTTP
Security Protocols & Features
IPsec, 802.1x, PING
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A
EN 61000-3-2, EN55022, IEC 61000-4-11, IEC 61000-4-3, IEC 61000-4-4, IEC 61000-4-5, IEC 61000-4-6, IEC 61000-4-8, EN 61000-3-3, EN55024, IEC 60950-1, EN 60950-1, IEC 60825-1, EN 60825-1
475 Watt
Power Consumption Stand by
69 Watt
Power Consumption Sleep
2.8 Watt
Software Included
Drivers & Utilities, EpsonNet Config
Limited warranty - 1 year - on-site
10 °C
30 °C
15 - 85%
Sound Emission (Idle)
39 dBA
Sound Emission (Operating)
54 dBA
44.4 cm
54.4 cm
35 cm
27.5 kg
BDVN C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
