Easy-to-use impact printer
If you need a hard worker that's easy to use and versatile, this is the ideal impact receipt printer.
- Epson TM U220A - receipt printer - colour - dot-matrix
- Printer Type
- Receipt printer - dot-matrix - 9 pin - colour
- 2.7 kg
- Max Media Size
- Roll (7.6cm)
- Max Media Size (Custom)
- 76 mm
- Print Speed
- Up to 6 lines/sec - max speed , Up to 4.7 lines/sec - colour
- Max Resolution (Colour)
- 17.8 cpi
- Cutter
- Interface
- Parallel
- Media Type
- Labels
- Fonts
- 2 fonts
- Total Media Capacity
- 1 roll
- Enclosure Colour
- Dark grey
- 16 cm x 28.6 cm x 15.8 cm
- Printer Type
- Enclosure Colour
- Dark grey
Printer
- Print Speed
- Up to 6 lines/sec - max speed - 16 cpi , Up to 4.7 lines/sec - colour - 16 cpi
- Built-in Devices
- Cutter
- Connectivity Technology
- Wired
- Interface
- Parallel
- 17.8 cpi
- Fonts
- 2 fonts
- Character Sizes (mm)
- 1.2 x 3.1 mm, 1.6 x 3.1 mm
- Columns
- 33, 35, 40, 42
- Auto Cutter
Media Handling
- Media Type
- Labels
- Max Media Size
- Roll (7.6cm)
- 76 mm
- Media Sizes
- Roll (7 cm), Roll (7.6cm), Roll (5.8 cm)
- Media Thickness Range
- 0.06 mm - 0.085 mm
- Roll Maximum Outer Diameter
- 83 mm
- 1 roll
- Media Feeders
- 1 x manual - 1 roll - Roll (7.6cm)
- Max Sheets in Multi-Part Form
- 2
- Connections
- 1 x parallel
- Included Accessories
- Take-up reel
- MTBF
- 180,000 hour(s)
- FCC Class A certified, CSA, UL, TUV, EN 60950, VCCI Class A ITE
- Power Device
- Power adapter - external
- 16 cm
- 28.6 cm
- 15.8 cm
- 2.7 kg
