Epson TM U220A Colour Dot-Matrix Receipt Printer
Quicklinx: 7NT9WS00 Mfr#: C31C513007
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired
Technology: Dot-matrix
£197.12 ex VAT
£236.54 inc VAT
1ST IMPACT PACKAGED PRINTER * PS, NES; Serial;Epson Cool White (ECW); Power Supply.
  • Easy-to-use impact printer
    If you need a hard worker that's easy to use and versatile, this is the ideal impact receipt printer.
Epson TM U220A - receipt printer - colour - dot-matrix
Printer Type
Receipt printer - dot-matrix - 9 pin - colour
2.7 kg
France
Max Media Size
Roll (7.6cm)
Max Media Size (Custom)
76 mm
Print Speed
Up to 6 lines/sec
Max Resolution (B&W)
16 cpi
Max Resolution (Colour)
16 cpi
Serial
Language Simulation
EPSON ESC/POS
Total Media Capacity
1 roll
DC 24 V
Enclosure Colour
Cool white
16 cm x 28.6 cm x 15.8 cm
Printer Type
Enclosure Colour
Cool white
France
Printer
Print Speed
Up to 6 lines/sec
Wired
Serial
16 cpi
16 cpi
Language Simulation
EPSON ESC/POS
Media Handling
Max Media Size
Roll (7.6cm)
76 mm
Media Sizes
Roll (7 cm), Roll (7.6cm), Roll (5.8 cm)
1 roll
Media Feeders
1 x manual - 1 roll - Roll (7.6cm)
1 x RS-232 - 9 pin D-Sub (DB-9)
Cutter, take-up reel
MTBF
180,000 hour(s)
FCC Class A certified, CSA, UL, TUV, EN 60950, EN55022, VCCI Class A ITE, EN55024
Power adapter - external
DC 24 V
31 Watt
Power Consumption Stand by / Sleep
2.2 Watt
Software Included
Driver
16 cm
28.6 cm
15.8 cm
2.7 kg
Type: Printer
Output Type: Colour
Max Print Speed: [N/A]
Max Paper Size: Roll (7.6cm)
Brand: Epson
Price Range Ex VAT: 150 - 300
