Epson TM-T88VI 112A0 Serial USB ENET Receipt Printer
Quicklinx: DN3SWS00 Mfr#: C31CE94112A0
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Max Paper Size: Roll (7.95 cm)
13 in stock
£206.93 ex VAT
£248.31 inc VAT
The Epson TM-T88V-i provides users with a straightforward and elegant printing solution, with no need for drivers. Ideal for use with tablet PCs or mobile phones, the TM-T88V-i is simple to use and maintain, with the ability to print from any device running an HTML 5 compatible web browser. In addition, the TM-T88V-i has grayscale printing for the addition of logos and images to receipts.
  • Future-proof receipt printer
    Reliable, fast receipt printer with mobile connectivity, which makes it easy to add web and mobile POS services to a traditional PC-based POS system.
Epson TM T88VI - receipt printer - B/W - thermal line
Printer Type
Receipt printer - thermal line - B/W
1.6 kg
United Kingdom
Max Media Size
Roll (7.95 cm)
Max Media Size (Custom)
80 mm
Print Speed
Up to 350 mm/sec - max speed
Max Resolution (B&W)
180 x 180 dpi
USB 2.0, LAN, serial, NFC, USB 2.0 host
Media Type
Thermal paper
PNE sensor, open cover sensor
Enclosure Colour
4 years warranty
14.5 cm x 19.5 cm x 14.8 cm
Printer Type
Receipt printer - thermal line - monochrome
Enclosure Colour
United Kingdom
Printer
Print Speed
Built-in Devices
Cutter, buzzer
Wired
180 x 180 dpi
Auto Cutter
Media Handling
Media Type
Thermal paper
Max Media Size
Roll (7.95 cm)
80 mm
Media Sizes
Roll (7.95 cm), Roll (5.75 cm)
Roll Maximum Outer Diameter
83 mm
Media Feeders
1 x manual - 1 roll - Roll (7.95 cm)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 host - 4 pin USB Type A , 1 x LAN - RJ-45 , 1 x serial
Paper roll spacer, power switch cover, connector cover
Media Included
Roll of media
MTBF
360,000 hour(s)
CSA, UL, EN55024
Power adapter - external
Limited warranty - 4 Years
5 °C
45 °C
10 - 90%
14.5 cm
19.5 cm
14.8 cm
1.6 kg
Type: Printer
Brand: Epson
Price Range Ex VAT: 150 - 300
