The Epson TM-T88V-i provides users with a straightforward and elegant printing solution, with no need for drivers. Ideal for use with tablet PCs or mobile phones, the TM-T88V-i is simple to use and maintain, with the ability to print from any device running an HTML 5 compatible web browser. In addition, the TM-T88V-i has grayscale printing for the addition of logos and images to receipts.
Versatile
The versatile Epson TM-T88VI receipt printer offers retailers, restaurants, bars and other commercial businesses the chance to explore web and mobile POS solutions without losing the functionality of a traditional PC-based system, as both can be run in parallel. This co-existence means users can migrate at the speed they want, run both systems at once, or just stick to a traditional setup. -
High performance and low running costs
As well as flexibility, the TM-T88VI gives outstanding performance, with print speeds of up to 350mm/s, and excellent reliability. A backward paper-feeding function helps save paper without affecting performance, reducing running costs and paper waste. -
Compact desktop
The TM-T88VI has exactly the same footprint as the TM-T88V, allowing you to upgrade to a brand new system without having to rearrange your counter space, and is available in both black and white to suit any shop, bar or restaurant decor.
- Epson TM T88VI - receipt printer - B/W - thermal line
- Printer Type
- Receipt printer - thermal line - B/W
- 1.6 kg
- Localisation
- United Kingdom
- Max Media Size
- Roll (7.95 cm)
- Max Media Size (Custom)
- 80 mm
- Print Speed
- Up to 350 mm/sec - max speed
- Max Resolution (B&W)
- 180 x 180 dpi
- Cutter
- Interface
- USB 2.0, LAN, serial, NFC, USB 2.0 host
- Media Type
- Thermal paper
- PNE sensor, open cover sensor
- Enclosure Colour
- Black
- 4 years warranty
- 14.5 cm x 19.5 cm x 14.8 cm
- Printer Type
- Receipt printer - thermal line - monochrome
- Enclosure Colour
- Black
- Localisation
- United Kingdom
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- 180 x 180 dpi
- Auto Cutter
Media Handling
- Media Type
- Thermal paper
- Max Media Size
- Roll (7.95 cm)
- 80 mm
- Media Sizes
- Roll (7.95 cm), Roll (5.75 cm)
- Roll Maximum Outer Diameter
- 83 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (7.95 cm)
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 host - 4 pin USB Type A , 1 x LAN - RJ-45 , 1 x serial
- Included Accessories
- Paper roll spacer, power switch cover, connector cover
- Media Included
- Roll of media
- MTBF
- 360,000 hour(s)
- CSA, UL, EN55024
- Power Device
- Power adapter - external
- Limited warranty - 4 Years - carry-in
- 5 °C
- 45 °C
- 10 - 90%
- 14.5 cm
- 19.5 cm
- 14.8 cm
- 1.6 kg
