Actual print speed is an impressive and efficient 300mm per second while multiple grey scale printing enables better representation of logos and graphic images. The TM-T88V works on several platforms, so it's simple to integrate into your network and it also comes with in-built USB IF which means easy migration to USB in the future.
This is a highly reliable and easy-to-use POS printer, but with the interest of the customer being paramount, we have included a 4-year warranty as standard.
This product meets the strict ENERGY STARĀ® guidelines set by the European Commission. Epson is a global manufacturer committed to protecting the environment for future generations by offering a range of ENERGY STARĀ® products. This is achieved by significantly reducing electricity usage, which saves energy, money and the environment, without compromising quality.
ENERGY STAR receipt printer
Go greener with the world's first ENERGY STAR qualified POS thermal receipt printer.
- Epson TM T88V - receipt printer - B/W - thermal line
- Printer Type
- Receipt printer - thermal line - B/W
- 1.6 kg
- Max Media Size
- Roll (8 cm)
- Max Media Size (Custom)
- 80 mm
- Print Speed
- Up to 300 mm/sec - max speed
- Cutter
- Interface
- USB, serial
- Barcodes
- Code 93, Code 39, GS1 DataBar, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, Codabar, Code 128, PDF417, ITF
- Media Type
- Thermal paper
- System Requirements
- Linux, Microsoft Windows 2000 / XP, Microsoft Windows 7, Apple MacOS X 10.4, Microsoft Windows Vista, Apple MacOS X 10.6, Apple MacOS X 10.5
- Microsoft Certification
- Works with Windows Vista
- Enclosure Colour
- Cool white
- 4 years warranty
- 14.5 cm x 19.5 cm x 14.8 cm
- Printer Type
- Receipt printer - thermal line - monochrome
- Enclosure Colour
- Cool white
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB, serial
- Character Sizes (mm)
- 1.41 x 3.39 mm, 0.99 x 2.4 mm
- Columns
- 30, 40, 42, 56
- Auto Cutter
- Barcodes
Media Handling
- Media Type
- Thermal paper
- Max Media Size
- Roll (8 cm)
- 80 mm
- Media Sizes
- Roll (8 cm), Roll (5.8 cm)
- Media Thickness Range
- 0.055 mm - 0.08 mm
- Roll Maximum Outer Diameter
- 83 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (8 cm)
- Connections
- 1 x RS-232 , 1 x USB 2.0 - 4 pin USB Type B
- MTBF
- 360,000 hour(s)
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- UL 1950, ICES-003 Class A, FCC, CSA C22.2 No. 950
- Power Device
- Power adapter
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 4 Years
- 14.5 cm
- 19.5 cm
- 14.8 cm
- 1.6 kg
