Epson TM-P20 (021):Reciept Cradle Wifi Belt Clip
Quicklinx: BX8YWS00 Mfr#: C31CE14021A0
Ultra light and compact
The TM-P20 is under half the size of our other two-inch model and around two-thirds lighter . It benefits from fast print speeds (up to 100mm/sec) and a battery life of up to eight hours, making it ideal for busy retail staff dealing with purchases on the shop floor, restaurant staff serving at tables and for producing tickets on-board busses and trains. The device also comes with a belt clip for hands-free transport.
Hassle-free connectivity
Our intelligent ePOS technology can control TM printers directly via web browsers or natively on many smart devices. Near field communication (NFC) functionality allows mobiles and/or tablets to be easily paired with the printers. Barcode pairing is also available for non-NFC devices to make handling faster and easier.
Robust
We know how frustrating delays can be. The TM-P20, therefore, comes with a number of features to help ensure continued operation. To help protect against those little accidents, the device has a drop impact resistance of 150 cm and, together with the optional soft case, it is IP-54 certified for shock and water resistance.
Easy to use
Simple and intuitive operation and LED light indications makes navigating the printer a breeze. Drop-in paper loading means easy paper changes, even on the go.
  • Ultra light and compact
    The TM-P20 is under half the size of our other two-inch model and around two-thirds lighter. It benefits from fast print speeds (up to 100mm/sec) and a battery life of up to eight hours, making it ideal for busy retail staff dealing with purchases on the shop floor, restaurant staff serving at tables and for producing tickets on-board busses and trains. The device also comes with a belt clip for hands-free transport.
  • Hassle-free connectivity
  • Robust
  • Easy to use
Epson TM P20 - receipt printer - B/W - thermal line
Printer Type
Receipt printer - thermal line - B/W
Portable
230 g
United Kingdom
Max Media Size
Roll (5.75 cm)
Print Speed
Up to 100 mm/sec
Max Resolution (B&W)
203 x 203 dpi
USB 2.0, Wi-Fi(n)
Print server
Included Qty 1
Enclosure Colour
7.9 cm x 12 cm x 4.4 cm
Printer Type
Receipt printer - thermal line - monochrome
Enclosure Colour
United Kingdom
Printer
Print Speed
Up to 100 mm/sec
Wireless
USB 2.0, Wi-Fi(n)
203 x 203 dpi
Media Handling
Max Media Size
Roll (5.75 cm)
Media Sizes
Roll (5.75 cm)
Max Printing Width
58 mm
Media Thickness Range
0.5 mm - 0.75 mm
Roll Core Diameter
40 mm
Media Feeders
1 x manual - 1 roll - Roll (5.75 cm)
Print server
1 x USB 2.0 - 4 pin mini-USB Type B
Belt clip, stand
1 x USB cable
Media Included
1 thermal roll paper
MTBF
120,000 hour(s)
FCC Class A certified
Power supply
Included
1
Run Time (Up To)
9 hour(s)
10 - 90%
Sound Emission (Operating)
57 dBA
7.9 cm
12 cm
4.4 cm
230 g
