Built for easy connectivity with tablets
By touching an NFC-equipped mobile device or tablet to the TM-m30 printer, it is easy to pair both together to print. ePOS print , the printer's built-in intelligence that communicates with web applications, allows direct printing from ANY mobile device without the need to install or update drivers. It is available for iOS, Android and Windows .
Position anywhere thanks to its sleek, compact and stylish design
With its sleek, stylish and compact design, the new TM-m30 is ideal for tablet POS applications and fits perfectly into small and medium-sized retail and hospitality environments, helping them to operate more efficiently and productively. With Ethernet, Bluetooth or Wi-Fi interfaces, it can be integrated into virtually any operating environment. By easily swapping just two covers the printer can be placed either horizontally or vertically - therefore top load or front load is possible.
High quality and adaptable
The new DM-D30 optional display is developed to match the modern design of the TM-m30 printer and an optional tablet stand is also available. Available in both black and white, this printer can print receipts in multiple greyscales, with advanced graphic and barcode printing capabilities that allow for highly customised layouts of receipts, including logos and promotional messages, that can be added with ease.
Gateway to tablet POS
Print receipts anywhere on the shop floor thanks to this printer's easy connectivity with any smart device and its compact and flexible design.
- Epson TM m30 - receipt printer - B/W - thermal line
- Printer Type
- Receipt printer - thermal line - B/W
- Max Media Size
- Roll (7.95 cm)
- Max Media Size (Custom)
- 80 mm
- Print Speed
- Up to 200 mm/sec - max speed
- Max Resolution (B&W)
- 203 x 203 dpi
- Cutter
- Interface
- USB, LAN, USB host, NFC
- Media Type
- Thermal paper
- PNE sensor
- Networking
- Print server
- Microsoft Certification
- Compatible with Windows 7
- Enclosure Colour
- White
- 12.7 cm x 12.7 cm x 12.7 cm
- Printer Type
- Receipt printer - thermal line - monochrome
- Enclosure Colour
- White
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- 203 x 203 dpi
- PNE sensor
- Auto Cutter
Media Handling
- Media Type
- Thermal paper
- Max Media Size
- Roll (7.95 cm)
- 80 mm
- Media Sizes
- Roll (7.95 cm), Roll (5.75 cm)
- Roll Maximum Outer Diameter
- 83 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (7.95 cm)
- Networking
- Print server
- Connections
- 1 x USB - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
- Media Included
- 1 thermal roll paper
- MTBF
- 360,000 hours
- Power Device
- Power adapter - external
- 5 °C
- 45 °C
- 10 - 90%
- Sound Emission (Operating)
- 55 dBA
- 12.7 cm
- 12.7 cm
- 12.7 cm
