Epson TM-L90 -412 S01 BUILT-IN USB
Quicklinx: BDPWWS00 Mfr#: C31C412412
Label and barcode printing
With fast, thermal printing of up to 150mm/sec, the TM-L90 is a valuable asset to your business. With this model, you'll be able to print out and get on with more important work, rather than waiting around for labels or barcodes.
More connectivity
This printer benefits from high speed serial, Ethernet and parallel connectivity plus a built-in USB interface, which means it can be operated as a network device.
Easy to use
The small footprint and wall bracket mean that you can place it almost anywhere, in any position, for convenient and versatile printing. Practical design features, such as drop-in paper load, selectable auto-cutter and jamproof paper feeding, ensure smooth operation. The easy-to-use operator cover and lifespan of up to 20 million lines enable long-lasting, trouble-free maintenance.
High quality labels
Its greyscale capabilities allow highly customised layouts, and logos and promotional messages can be added with ease.
Larger receipt rolls, wider paper
Altogether, the TM-L90 label printer is one of the most efficient label printers available: it accepts large paper rolls (up to 90mm in diameter) and you can select paper widths between 38 and 80mm to produce labels in different sizes.
  • Label printer
    The compact label printer that can be installed almost anywhere for fast, reliable and versatile printing.
Epson TM L90 - receipt printer - B/W - thermal line
Printer Type
Receipt printer - thermal line - B/W
1.9 kg
Max Media Size
Roll (8 cm)
Max Media Size (Custom)
80 mm
Print Speed
Up to 150 mm/sec - max speed
Max Resolution (B&W)
203 dpi
Cutter
USB 2.0, serial
RAM Installed (Max)
4 KB
Media Type
Labels, receipt paper
Microsoft Certification
Compatible with Windows 7
Enclosure Colour
Dark grey
14 cm x 14.8 cm x 20.3 cm
Printer Type
Receipt printer - thermal line - monochrome
Enclosure Colour
Dark grey
Printer
Print Speed
Wired
USB 2.0, serial
203 dpi
Character Sizes (mm)
1.5 x 3 mm, 1.1 x 2.1 mm
Columns
38, 70
Cutter
Fonts Included
1 x barcode
RAM
RAM Installed (Max)
4 KB
Media Handling
Media Type
Max Media Size
Roll (8 cm)
80 mm
Media Sizes
Roll (8 cm)
Roll Maximum Outer Diameter
90 mm
Media Feeders
1 x manual - 1 roll - Roll (8 cm)
1 x USB 2.0 - 4 pin USB Type B , 1 x serial
Paper roll spacer, power switch cover
Media Included
1 thermal roll paper
MTBF
360,000 hour(s)
FCC Class A certified, CSA, UL, TUV, AS/NZS 3548, VCCI Class A
Power adapter - external
5 °C
45 °C
10 - 90%
Sound Emission (Operating)
53 dBA
14 cm
14.8 cm
20.3 cm
1.9 kg
