Ideal for graphics, CAD and GIS
The SureColor SC-T5200 is one of the SureColor SC-T series of high-speed, four-color large-format printers, designed to produce a wide range of high-quality graphics, CAD and GIS applications in design, commercial print, copy shop, architecture, building, engineering, retail and education environments.
Highly productive
To maximise productivity, the SureColor SC-T5200 features 1GB of RAM for ultra-fast image processing, and an optional 320GB HDD for job caching and recall. Optional PostScript support with dual 1.6GHz CPUs enables printing of large data-rich files quickly and directly from leading design and CAD programs. And the SureColor SC-T5200 is fast — outputting an A1 print takes just 28 seconds.
Compact, quiet and easy to use
With its sleek styling, compact footprint, low noise levels and front operation, the SureColor SC-T5200 is designed to fit easily into an office environment.
The SureColor SC-T5200 is one of the SureColor SC-T series of high-speed, four-colour large-format printers, designed to produce a wide range of high-quality graphics, CAD and GIS applications in design, commercial print, copy shop, architecture, building, engineering, retail and education environments. -
High quality output
The combination of Epson's PrecisionCore TFP printheads and UltraChrome XD pigment ink delivers industry-leading output quality and precise, repeatable performance. UltraChrome XD pigment ink is smudge and water resistant and delivers deep blacks and crisp, dense lines - ideal for technical graphics - and the vibrant colours necessary for high-quality prints and posters, on coated and non-coated media - including board up to 1.5mm thick. -
- Epson SureColor SC-T5200 - large-format printer - colour - ink-jet
- Printer Type
- 36" large-format printer - ink-jet - colour
- 84 kg
- Inkjet Technology
- Epson PrecisionCore
- Ink Palette Supported (Colours)
- 4-ink - cyan, magenta, yellow, photo black or matte black
- Max Media Size
- Roll (91.4 cm)
- Max Media Size (Custom)
- 914 mm
- Print Speed
- Up to 2.14 ppm - colour - A1 (594 x 841 mm) , Up to 2.14 ppm - B/W - A1 (594 x 841 mm)
- Max Resolution (B&W)
- 2880 x 1440 dpi
- Max Resolution (Colour)
- 2880 x 1440 dpi
- Cutter
- Interface
- USB 2.0, Gigabit LAN
- RAM Installed (Max)
- 256 MB
- Language Simulation
- HP RTL, HP GL/2, EPSON ESC/P Raster
- Media Type
- Plain paper
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Apple MacOS X 10.5.8 or later, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 64-bit Edition, Microsoft Windows Server 2012 R2, Windows 8.1
- Microsoft Certification
- Compatible with Windows 7
- 140.5 cm x 81.3 cm x 112.8 cm
- Printer Type
Printer
- Inkjet Technology
- Nozzle Configuration
- 720 nozzles (black), 720 nozzles (per color)
- Minimum Ink Droplet Size
- 3.5 pl
- Ink Cartridge Configuration
- 5 individual ink tanks
- Ink Type
- Epson UltraChrome XD Ink
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 2880 x 1440 dpi
- 2880 x 1440 dpi
- PostScript Support
- Optional
- Cutter
RAM
- 256 MB
Media Handling
- Media Type
- Plain paper
- Max Media Size
- Roll (91.4 cm)
- 914 mm
- Media Sizes
- A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), A0 (841 x 1189 mm), B4 (250 x 353 mm), B3 (353 x 500 mm), B2 (500 x 707 mm), Roll (43.2 cm), Roll (91.4 cm), Roll (61 cm), A3 Plus (329 x 483 mm)
- Media Thickness Range
- 0.08 mm - 1.5 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (91.4 cm)
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (photo black) , 1 x ink cartridge (matte black)
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 65 Watt
- Power Consumption Stand by
- 3 Watt
- Software Included
- Drivers & Utilities
- OS Required
- Sound Emission (Operating)
- 50 dBA
- 140.5 cm
- 81.3 cm
- 112.8 cm
- 84 kg
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.37 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.37 |
Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) | In Stock | £14.69 |
Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) | In Stock | £21.42 |
Epson A3 Matte Paper Heavyweight 50 sheets | In Stock | £29.33 |
