Epson SureColor SC-P800 Colour Ink-Jet Printer
Quicklinx: BLNQWS00 Mfr#: C11CE22301BX
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Ink-jet
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
£871.65 ex VAT
£1,045.98 inc VAT
Superior quality prints
Using UltraChrome HD ink, our new nine-colour ink-set, the SC-P800 produces true-to-life photos with vivid colours and the deepest blacks on the market . Your prints will last for ages thanks to the inks' improved lightfastness , and large 80ml ink cartridges mean fewer trips to change the ink.
Print on a range of media
The SC-P800 is the smallest A2 printer with roll paper option , which enables users to print panoramic photos on formats such as banners and gallery wrap canvas. Three paper paths, including a front-loading fine art paper path, means users can easily switch between different formats.
Stay connected
With the SC-P800, it is easier than ever before to print from a whole range of devices. This model is the first 17-inch photo printer with wireless functionality and Epson Connect compatibility for great flexibility and freedom, meaning easy printing from tablets, PCs and smartphones. Wi-Fi Direct is also supported, meaning the printer can easily communicate with your smart devices.
Easy-to-use
The SC-P800 features quick, simple set-up and operation thanks to a large 2.7-inch colour touch panel. It guides the user through how to load different media types and enables them to easily switch between these before printing.
High-quality look and feel
A new sleek, modern design means the printer has the smallest footprint of any A2 printer on the market and it fits well where space is an issue, at home or in the studio.
  • A2 desktop photo printer
    Superior-quality A2 photo printer with flexible connectivity and roll paper option for creating professional prints on a range of media.
Epson SureColor SC-P800 - large-format printer - colour - ink-jet
Printer Type
17" large-format printer - ink-jet - colour
19.5 kg
Inkjet Technology
Epson On-demand Inkjet
Ink Palette Supported (Colours)
8-ink - cyan, vivid magenta, yellow, light black, light cyan, vivid light magenta, light light black, photo black or matte black
Max Media Size
Roll (43.2 cm)
Max Media Size (Custom)
432 mm
Print Speed
Up to 3 ppm - B/W (ISO/IEC 24734) , Up to 3 ppm - colour (ISO/IEC 24734)
Max Resolution (B&W)
2880 x 1440 dpi
Max Resolution (Colour)
2880 x 1440 dpi
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Preview Screen Size
2.7"
Media Type
Envelopes, plain paper, photo paper, glossy photo paper, CD/DVD labels, glossy paper
Total Media Capacity
120 sheets
Media Handling
120-sheet input tray, CD/DVD tray, 1-sheet manual tray
Print server
AC 230V
Microsoft Windows XP 64-bit Edition, Microsoft Windows XP SP1 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.6.8 or later, Windows 8 (32/64 bits), Android 4.0 or later, Windows 8.1 (32/64 bits), Apple iOS 7
1-year warranty
68.4 cm x 37.6 cm x 25 cm
Printer Type
Printer
Inkjet Technology
Nozzle Configuration
180 nozzles (black), 180 nozzles (per colour)
Minimum Ink Droplet Size
3.5 pl
Ink Cartridge Configuration
8 individual ink tanks
Ink Type
Epson UltraChrome HD Ink
Print Speed
Built-in Devices
Touch screen
Preview Screen Size
2.7"
Wireless
AirPrint Enabled
2880 x 1440 dpi
2880 x 1440 dpi
Media Handling
Media Handling
Media Type
Max Media Size
Roll (43.2 cm)
432 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), B4 (250 x 353 mm), B3 (353 x 500 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, Roll (43.2 cm), B6 (125 x 176 mm), 200 x 250 mm, 130 x 200 mm, A3 Plus (329 x 483 mm)
Envelope Sizes
International C6 (114 x 162 mm), International C5 (162 x 229 mm), International C4 (229 x 324 mm)
Media Thickness Range
0.29 mm - 1.5 mm
Media Weight
73 g/m² - 1000 g/m²
120 sheets
Media Feeders
1 x manual - 1 roll - Roll (43.2 cm) , 1 x automatic - 120 sheets
Print server
Security Protocols & Features
WEP, WPA-PSK, WPA2, Wi-Fi Direct
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x ink cartridge (cyan) , 1 x ink cartridge (vivid magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (photo black) , 1 x ink cartridge (matte black) , 1 x ink cartridge (light black) , 1 x ink cartridge (light light black) , 1 x ink cartridge (light cyan) , 1 x ink cartridge (vivid light magenta)
Power supply - internal
AC 230V
Frequency Required
50 - 60 Hz
21 Watt
Power Consumption Sleep
1.8 Watt
Limited warranty - 1 year - on-site
68.4 cm
37.6 cm
25 cm
19.5 kg
Ink (7)
BLNQ Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £12.88
BLNQ Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £9.92
BLNQ Epson Matte Paper Heavyweight A4 50 sheets In Stock £9.92
BLNQ Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £12.41
BLNQ Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) In Stock £12.00
BLNQ Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) In Stock £19.38
BLNQ Epson A3 Matte Paper Heavyweight 50 sheets In Stock £24.79
Other bundles (2)
BLNQ C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.10
BLNQ C2G 2m Cat6a Shielded Patch - Blue In Stock £6.60
Type: Printer
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: Roll (43.2 cm)
Brand: Epson
Price Range Ex VAT: 750 - 1000
