Wide colour gamut
Featuring an UltraChrome HDX ten-colour pigment ink-set, the SC-P7000 STD delivers 98% of Pantone-certified colours to create superior-quality, highly-accurate results with bright, vivid colours. For stunning prints, an Advanced Black and White Mode helps produce high density, deep, rich blacks and ultra-smooth tones.
Reliable and efficient
Utilising an Epson TFP PrecisionCore printhead and automated nozzle-check function, users can be sure they will deliver consistent results and the highest quality output. Consistent colour reproduction is guaranteed, time after time and without the need for expensive add ons, thanks to an Epson Colour Calibration utility and optional Spectroproofer powered by X-Rite for fast, accurate colour measurement.
Easy to use and cost-effective
Every aspect of the printer has been designed to maximise ease of use and reliability. Media changing is fast and simple with a clear LCD control panel and menu, while a choice of 350ml and 700ml individual cartridges enables longer print runs between cartridge replacements. With an optional 320Gb hard disk, users can free up their computer and store multiple jobs onto the printer ready for output.
Long-lasting results
Thanks to a superior lightfastness, prints will continue to look their best long after they are created. In fact, prints on Premium Glossy Photo Paper can last a minimum of 60 years .
Wide colour gamut
Featuring an UltraChrome HDX ten-colour pigment ink-set, the SC-P7000 STD delivers 98% of Pantone-certified colours to create superior-quality, highly-accurate results with bright, vivid colours. For stunning prints, an Advanced Black and White Mode helps produce high density, deep, rich blacks and ultra-smooth tones. -
Utilising an Epson TFP PrecisionCore printhead and automated nozzle-check function, users can be sure they will deliver consistent results and the highest quality output. Consistent colour reproduction is guaranteed, time after time and without the need for expensive add ons, thanks to an Epson Colour Calibration utility and optional Spectroproofer powered by X-Rite for fast, accurate colour measurement. -
Every aspect of the printer has been designed to maximise ease of use and reliability. Media changing is fast and simple with a clear LCD control panel and menu, while a choice of 350ml and 700ml individual cartridges enables longer print runs between cartridge replacements. With an optional 320Gb hard disk, users can free up their computer and store multiple jobs onto the printer ready for output. -
Thanks to a superior lightfastness, prints will continue to look their best long after they are created. In fact, prints on Premium Glossy Photo Paper can last a minimum of 60 years.
- Epson SureColor SC-P7000 - large-format printer - colour - ink-jet
- Printer Type
- 24" large-format printer - ink-jet - colour
- 140 kg
- Inkjet Technology
- Epson PrecisionCore TFP
- Ink Palette Supported (Colours)
- 10-ink - cyan, vivid magenta, yellow, light black, light cyan, vivid light magenta, light light black, photo black or matte black
- Max Media Size
- Roll (61 cm)
- Max Media Size (Custom)
- 610 mm
- Max Resolution (B&W)
- 2880 x 1440 dpi
- Max Resolution (Colour)
- 2880 x 1440 dpi
- Interface
- Gigabit LAN, USB 2.0
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Windows 8.1, Apple MacOS X 10.9.x
- 80.1 cm x 94.5 cm x 151.6 cm
- Printer Type
Printer
- Inkjet Technology
- Nozzle Configuration
- 10 x 360 nozzles
- Minimum Ink Droplet Size
- 3.5 pl
- Ink Cartridge Configuration
- 11 cartridges (1 each:cyan, vivid magenta, yellow, light black, light cyan, vivid light magenta, light light black, orange, green, photo black, matte black)
- Ink Type
- Epson UltraChrome HDX Ink
- Connectivity Technology
- Wired
- Interface
- 2880 x 1440 dpi
- 2880 x 1440 dpi
Media Handling
- Max Media Size
- Roll (61 cm)
- 610 mm
- Media Sizes
- A4 (210 x 297 mm), A3 (297 x 420 mm), A2 (420 x 594 mm), A1 (594 x 841 mm), B4 (250 x 353 mm), B3 (353 x 500 mm), B2 (500 x 707 mm), Roll (43.2 cm), Roll (61 cm), A3 Plus (329 x 483 mm)
- Media Thickness Range
- 0.08 mm - 1.5 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (61 cm)
- Networking
- Print server
- Connections
- 1 x USB 2.0 , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (green) , 1 x ink cartridge (orange) , 1 x ink cartridge (vivid light magenta) , 1 x ink cartridge (vivid magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (light cyan) , 1 x ink cartridge (cyan) , 1 x ink cartridge (matte black) , 1 x ink cartridge (photo black) , 1 x ink cartridge (light light black) , 1 x ink cartridge (light black)
- Power Device
- Power supply - internal
- 70 Watt
- Power Consumption Stand by
- 5.4 Watt
- OS Required
- 80.1 cm
- 94.5 cm
- 151.6 cm
- 140 kg
Ink (20)
Epson 24" x 18m Watercolour (Radiant White) | In Stock | £86.03 |
Epson Premium Semi-Gloss Photo A3 20 Pack | In Stock | £32.62 |
Epson Photo Quality InkJet Paper | In Stock | £28.19 |
Epson A3+ Watercolour Paper - Radiant White (20 Sheets) | In Stock | £29.68 |
Epson Archival Matte Paper A3 50 Sheets | In Stock | £31.22 |
Epson Heavy Weight Matte Paper A3+ 50 Sheets | In Stock | £39.08 |
Epson A2 Premium Semi-Gloss Photo Paper 25 Sheets | In Stock | £34.52 |
Epson Presentation Matte Paper Roll 24"x 25m | In Stock | £42.34 |
Epson Enhanced Matte Paper Roll 24" x 30.5m | In Stock | £75.77 |
Epson Premium Glossy Photo Paper Roll 24" x 30.5m | In Stock | £106.18 |
Epson Premium Semi-Gloss Photo Paper 24" x 30.5m | In Stock | £106.18 |
Epson Premium Semi-Gloss Photo Paper 61 cm x 30.5m | In Stock | £126.50 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £12.79 |
Epson Singlepack Yellow T804400 UltraChrome HDX/HD 700ml | In Stock | £211.38 |
Epson Singlepack Orange T804A00 UltraChrome HDX 700ml | In Stock | £211.38 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £12.79 |
Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) | In Stock | £16.53 |
Epson A3+ Glossy Photo Paper | In Stock | £22.01 |
Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) | In Stock | £22.01 |
Epson A3 Matte Paper Heavyweight 50 sheets | In Stock | £29.42 |
Other bundles (3)
Epson A2 Premium Glossy Photo Paper - 25 Sheets | In Stock | £37.72 |
Epson DOUBLEWEIGHT MATTE PAPER (180GSM) | In Stock | £57.87 |
Epson 24" x 50m Standard Proofing Paper | In Stock | £176.11 |
