Professional quality
Epson’s nine-colour UltraChrome HD inkset with Vivid Magenta reproduces a wide colour gamut to produce superb quality prints. The highest black density¹ (2.86 DMax on PGPP) produces deep, rich blacks and ultra-smooth tonal gradation.
Easy-to-use
Featuring a large 2.7 inch colour touch panel, the printer is simple to set up and manage, even without a PC. Automatic Wi-Fi set up² makes connectivity a breeze.
Stay connected
Exceptional Wi-Fi Direct® wireless connectivity makes it easy to print from smartphones, tablets and PCs, alongside Epson Connect³ support. Apple AirPrint4 supported. Google Cloud Print also supported.
Flexible printing
Twin paper paths enable A3+ printing on a wide variety of photo and fine art papers, canvas and thick media, while the machine’s roll-paper capability is perfect for high-impact panoramic images.
Quality, speed and mobile connectivity
Fast, flexible and professional-quality A3+ photo printer with user-friendly touch screen, exceptional Wi-Fi and Cloud printing connectivity. -
New inkset for exceptional images
With the SureColor SC-P600's new nine-colour UltraChrome HD and Vivid Magenta ink you can print an exceptionally wide colour gamut with smooth tones. Featuring the industry's highest density (2.86 DMax on PGPP) the printer reproduces deep, rich blacks and ultra-smooth tonal gradation. -
Fast and flexible
Built for speed this printer outputs an 13 x 19 inch print in only 153 seconds. It gives you the ability to print a range of sizes (up to A3+) on a wide variety of photo and art papers, canvas and thick media. Take advantage of the roll-fed capability to print high-impact panoramic images. -
Simple to use
Operating the SureColor SC-P600 couldn't be easier with the large 2.7 inch colour touch control panel - a unique feature in this market sector4. Automatic Wi-Fi set up5 makes connectivity a breeze. -
Compact footprint
Measuring just 616 x 369 x 228mm, the SureColor SC-P600 fits in well wherever space is an issue, at home or in the studio. -
Large cartridge size
The generous 25.9ml cartridge size is ideal for medium volumes of professional-quality photo prints.
- Epson SureColor SC-P600 - large-format printer - colour - ink-jet
- Printer Type
- 13" large-format printer - ink-jet - colour
- 15 kg
- Inkjet Technology
- Epson Micro Piezo with Active Meniscus Control (AMC)
- Ink Palette Supported (Colours)
- 8-ink - cyan, vivid magenta, yellow, light black, light cyan, vivid light magenta, light light black, photo black or matte black
- Media Size Class
- A3/Ledger
- Max Media Size
- Super A3/B (330 x 483 mm), Roll (33 cm), A3 Plus (329 x 483 mm)
- Max Media Size (Custom)
- 330 mm x 483 mm
- Print Speed
- Up to 6 ppm - B/W , Up to 6 ppm - colour
- Max Resolution (B&W)
- 5760 x 1440 dpi
- Max Resolution (Colour)
- 5760 x 1440 dpi
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Preview Screen Size
- 2.7"
- Language Simulation
- EPSON ESC/P 2
- Media Type
- Plain paper, CD/DVD labels
- Total Media Capacity
- 120 sheets
- Media Handling
- 120-sheet input tray, CD/DVD tray, 1-sheet manual tray
- Networking
- Print server
- Power
- AC 230V
- System Requirements
- Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7.x, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Apple MacOS X 10.9.x
- 61.6 cm x 36.9 cm x 22.8 cm
- Printer Type
Printer
- Inkjet Technology
- Nozzle Configuration
- 180 nozzles (black), 180 nozzles (per colour)
- Minimum Ink Droplet Size
- 2 pl
- Ink Cartridge Configuration
- 8 individual ink tanks
- Ink Type
- Epson UltraChrome HD Ink
- Print Speed
- Built-in Devices
- Touch screen
- 2.7"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 5760 x 1440 dpi
- 5760 x 1440 dpi
- EPSON ESC/P 2
- Media Handling
Media Handling
- Media Type
- Media Size Class
- A3/Ledger
- Max Media Size
- 330 mm x 483 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm), Super A3/B (330 x 483 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 89 x 127 mm, 200 x 250 mm, 130 x 200 mm, A3 Plus (329 x 483 mm)
- Max Printing Length
- 3276.6 mm
- Media Thickness Range
- 0.08 mm - 1.3 mm
- 120 sheets
- Media Feeders
- 1 x manual - 1 roll - Roll (33 cm) , 1 x automatic - 120 sheets - Super A3/B (330 x 483 mm)
- Networking
- Print server
- WEP, WPA-PSK, Wi-Fi Direct
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (cyan) , 1 x ink cartridge (vivid magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (photo black) , 1 x ink cartridge (matte black) , 1 x ink cartridge (light black) , 1 x ink cartridge (light light black) , 1 x ink cartridge (light cyan) , 1 x ink cartridge (vivid light magenta)
- CSA 22.2 No. 950, FCC Part 15 B, CSA C108.8 Class B, FDA, AS/NZS 3548 Class B, EMI
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50 - 60 Hz
- 20 Watt
- Power Consumption Stand by
- 1.4 Watt
- Power Consumption Sleep
- 0.3 Watt
- Software Included
- Drivers & Utilities, EPSON Print CD, EPSON Easy Photo Print, EpsonNet Print, EpsonNet Config
- OS Required
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 38 dBA
- 61.6 cm
- 36.9 cm
- 22.8 cm
- 15 kg
- Width (Shipping)
- 62.5 cm
- Depth (Shipping)
- 56 cm
- Height (Shipping)
- 50.5 cm
- Weight (Shipping)
- 30.21 kg
Ink (8)
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £12.88 |
Epson Premium Semigloss Photo Paper Roll 10m x 329mm | In Stock | £27.92 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £9.84 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £9.84 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £12.30 |
Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) | In Stock | £11.87 |
Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) | In Stock | £19.63 |
Epson A3 Matte Paper Heavyweight 50 sheets | In Stock | £24.46 |
Other bundles (1)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.11 |
