Epson SureColor SC-P600 Colour Inkjet Printer
Quicklinx: B7N3WS00 Mfr#: C11CE21301
Type: Printer
Functionality: Printer
Output Type: Colour
Wireless Capability: Wired, Wireless
Technology: Ink-jet
  • Windows 8 (32/64 bits)
13 in stock
£517.59 ex VAT
£621.10 inc VAT
Professional quality
Epson’s nine-colour UltraChrome HD inkset with Vivid Magenta reproduces a wide colour gamut to produce superb quality prints. The highest black density¹ (2.86 DMax on PGPP) produces deep, rich blacks and ultra-smooth tonal gradation.
Easy-to-use
Featuring a large 2.7 inch colour touch panel, the printer is simple to set up and manage, even without a PC. Automatic Wi-Fi set up² makes connectivity a breeze.
Stay connected
Exceptional Wi-Fi Direct® wireless connectivity makes it easy to print from smartphones, tablets and PCs, alongside Epson Connect³ support. Apple AirPrint4 supported. Google Cloud Print also supported.
Flexible printing
Twin paper paths enable A3+ printing on a wide variety of photo and fine art papers, canvas and thick media, while the machine’s roll-paper capability is perfect for high-impact panoramic images.
  • Quality, speed and mobile connectivity
    Fast, flexible and professional-quality A3+ photo printer with user-friendly touch screen, exceptional Wi-Fi and Cloud printing connectivity.
  • New inkset for exceptional images
    With the SureColor SC-P600's new nine-colour UltraChrome HD and Vivid Magenta ink you can print an exceptionally wide colour gamut with smooth tones. Featuring the industry's highest density (2.86 DMax on PGPP) the printer reproduces deep, rich blacks and ultra-smooth tonal gradation.
  • Fast and flexible
    Built for speed this printer outputs an 13 x 19 inch print in only 153 seconds. It gives you the ability to print a range of sizes (up to A3+) on a wide variety of photo and art papers, canvas and thick media. Take advantage of the roll-fed capability to print high-impact panoramic images.
  • Simple to use
    Operating the SureColor SC-P600 couldn't be easier with the large 2.7 inch colour touch control panel - a unique feature in this market sector4. Automatic Wi-Fi set up5 makes connectivity a breeze.
  • Compact footprint
    Measuring just 616 x 369 x 228mm, the SureColor SC-P600 fits in well wherever space is an issue, at home or in the studio.
  • Large cartridge size
    The generous 25.9ml cartridge size is ideal for medium volumes of professional-quality photo prints.
Epson SureColor SC-P600 - large-format printer - colour - ink-jet
Printer Type
13" large-format printer - ink-jet - colour
15 kg
Inkjet Technology
Epson Micro Piezo with Active Meniscus Control (AMC)
Ink Palette Supported (Colours)
8-ink - cyan, vivid magenta, yellow, light black, light cyan, vivid light magenta, light light black, photo black or matte black
Media Size Class
A3/Ledger
Max Media Size
Super A3/B (330 x 483 mm), Roll (33 cm), A3 Plus (329 x 483 mm)
Max Media Size (Custom)
330 mm x 483 mm
Print Speed
Up to 6 ppm - B/W , Up to 6 ppm - colour
Max Resolution (B&W)
5760 x 1440 dpi
Max Resolution (Colour)
5760 x 1440 dpi
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Preview Screen Size
2.7"
Language Simulation
EPSON ESC/P 2
Media Type
Plain paper, CD/DVD labels
Total Media Capacity
120 sheets
Media Handling
120-sheet input tray, CD/DVD tray, 1-sheet manual tray
Print server
AC 230V
Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7.x, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Apple MacOS X 10.9.x
61.6 cm x 36.9 cm x 22.8 cm
Printer Type
Printer
Inkjet Technology
Nozzle Configuration
180 nozzles (black), 180 nozzles (per colour)
Minimum Ink Droplet Size
2 pl
Ink Cartridge Configuration
8 individual ink tanks
Ink Type
Epson UltraChrome HD Ink
Print Speed
Built-in Devices
Touch screen
Preview Screen Size
2.7"
Wireless
AirPrint Enabled
5760 x 1440 dpi
5760 x 1440 dpi
Language Simulation
EPSON ESC/P 2
Media Handling
Media Handling
Media Type
Media Size Class
A3/Ledger
Max Media Size
330 mm x 483 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm), Super A3/B (330 x 483 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 89 x 127 mm, 200 x 250 mm, 130 x 200 mm, A3 Plus (329 x 483 mm)
Max Printing Length
3276.6 mm
Media Thickness Range
0.08 mm - 1.3 mm
120 sheets
Media Feeders
1 x manual - 1 roll - Roll (33 cm) , 1 x automatic - 120 sheets - Super A3/B (330 x 483 mm)
Print server
Security Protocols & Features
WEP, WPA-PSK, Wi-Fi Direct
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x ink cartridge (cyan) , 1 x ink cartridge (vivid magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (photo black) , 1 x ink cartridge (matte black) , 1 x ink cartridge (light black) , 1 x ink cartridge (light light black) , 1 x ink cartridge (light cyan) , 1 x ink cartridge (vivid light magenta)
CSA 22.2 No. 950, FCC Part 15 B, CSA C108.8 Class B, FDA, AS/NZS 3548 Class B, EMI
Power supply - internal
AC 230V
Frequency Required
50 - 60 Hz
20 Watt
Power Consumption Stand by
1.4 Watt
Power Consumption Sleep
0.3 Watt
Software Included
Drivers & Utilities, EPSON Print CD, EPSON Easy Photo Print, EpsonNet Print, EpsonNet Config
10 °C
35 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
38 dBA
61.6 cm
36.9 cm
22.8 cm
15 kg
Width (Shipping)
62.5 cm
Depth (Shipping)
56 cm
Height (Shipping)
50.5 cm
Weight (Shipping)
30.21 kg
Ink (7)
B7N3 Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £13.72
B7N3 Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £10.01
B7N3 Epson Matte Paper Heavyweight A4 50 sheets In Stock £10.01
B7N3 Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £12.51
B7N3 Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) In Stock £12.41
B7N3 Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) In Stock £19.52
B7N3 Epson A3 Matte Paper Heavyweight 50 sheets In Stock £24.87
Other bundles (3)
B7N3 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.27
B7N3 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £12.18
B7N3 C2G 2m Cat6a Shielded Patch - Blue In Stock £7.49
Type: Printer
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
Max Print Speed: [N/A]
Max Paper Size: A3 Plus (329 x 483 mm)
Max Paper Size: Roll (33 cm)
Max Paper Size: Super A3/B (330 x 483 mm)
Brand: Epson
Price Range Ex VAT: 500 - 750
