Epson Stylus Photo 1500W Colour Inkjet Printer
Quicklinx: 85KHWS00 Mfr#: C11CB53301
Wireless convenience
The Stylus Photo 1500W can print from anywhere thanks to built-in Wi-Fi support, allowing convenient and easy printing from laptops, desktops and the latest generation of mobile devices such as iPhones and iPads using Epson's free iPrint app.
Print photos, iron-on transfers, CDs and more
A wide range of printing projects can be undertaken with the 1500W, which prints on glossy paper, plain paper, envelopes, iron-on transfers plus CDs and DVDs. Standard 4 x 6 inch (10 x 15cm) photos all the way up to panoramic and A3+ prints are supported.
Glossy, long-lasting prints
The 1500W uses Epson’s Claria 6-colour, dye-based ink-set to achieve vivid and long-lasting results with a glossy finish. Coupled with the resolution up to of 5760 x 1440dpi and small 1.5pl droplet size, this yields high-quality prints with fine detail and smooth tonal gradations.
  • Wireless convenience
  • Print photos, iron-on transfers, CDs and more
  • Glossy, long-lasting prints
    The 1500W uses Epson’s Claria 6-color, dye-based ink-set to achieve vivid and long-lasting results with a glossy finish. Coupled with the resolution up to of 5760 x 1440dpi and small 1.5pl droplet size, this yields high-quality prints with fine detail and smooth tonal gradations.
Epson Stylus Photo 1500W - printer - colour - ink-jet
Printer Type
Photo printer - ink-jet - colour
11.8 kg
Inkjet Technology
Epson Micro Piezo
Ink Palette Supported (Colours)
6-ink - cyan, magenta, yellow, black, light cyan, light magenta
Max Media Size
A3 plus (329 x 423 mm)
Print Speed
Up to 3.3 min/page - photo - A3 plus (329 x 423 mm) , Up to 0.75 min/page - photo - 100 x 150 mm
Max Resolution (B&W)
5760 x 1440 dpi
Max Resolution (Colour)
5760 x 1440 dpi
Print on CD/DVD
USB, Wi-Fi(n), USB host
Media Type
Envelopes, plain paper, glossy photo paper, CD/DVD labels
Total Media Capacity
100 sheets
Print server - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
AC 230V
Apple MacOS X 10.4.11 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
Microsoft Certification
Compatible with Windows 7
1 year warranty
61.6 cm x 32.2 cm x 21.5 cm
Printer Type
Printer
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
6 x 90 nozzles
Minimum Ink Droplet Size
1.5 pl
Ink Cartridge Configuration
6 individual ink tanks
Ink Type
Epson Claria Photographic Ink
Print Speed
Wireless
5760 x 1440 dpi
5760 x 1440 dpi
Print on CD/DVD
Direct Printing Specifications
PictBridge
Media Handling
Media Type
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), 100 x 150 mm, A3 plus (329 x 423 mm), 130 x 180 mm, 90 x 130 mm, CD (120 mm), CD (80 mm), 200 x 250 mm, 130 x 200 mm
Envelope Sizes
International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm)
Max Printing Width
329 mm
Max Printing Length
1117 mm
100 sheets
Media Feeders
1 x automatic - 100 sheets
Print server
Security Protocols & Features
WEP, WPA-PSK, TKIP, AES
1 x USB 2.0 - 4 pin USB Type B , 1 x direct print port - USB 2.0 - 4 pin USB Type A
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
18 Watt
Power Consumption Stand by / Sleep
3.5 Watt
Software Included
EPSON Print CD, EPSON Easy Photo Print, Epson iPrint 2.0
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
Sound Emission (Operating)
45 dBA
61.6 cm
32.2 cm
21.5 cm
11.8 kg
Width (Shipping)
70.7 cm
Depth (Shipping)
43.9 cm
Height (Shipping)
31.8 cm
Weight (Shipping)
12.1 kg
85KH Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £13.08
85KH Epson C13T079140A0 Black Ink Cartridge for Photo 1400 In Stock £12.47
85KH Epson C13T079340A0 Magenta Ink Cartridge for Photo 1400 In Stock £12.47
85KH Epson C13T079640A0 Light Magenta Ink Cartridge In Stock £12.47
85KH Epson C13T079440A0 Yellow Ink Cartridge for Photo 1400 In Stock £12.47
85KH Epson C13T079240A0 Cyan Ink Cartridge for Photo 1400 In Stock £12.47
85KH Epson C13T079540A0 Light Cyan Ink for Photo 1400 In Stock £12.47
85KH Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £9.51
85KH Epson Matte Paper Heavyweight A4 50 sheets In Stock £9.51
85KH Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £11.89
85KH Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) In Stock £11.89
85KH Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) In Stock £18.56
85KH Epson A3 Matte Paper Heavyweight 50 sheets In Stock £23.63
