Wireless convenience
The Stylus Photo 1500W can print from anywhere thanks to built-in Wi-Fi support, allowing convenient and easy printing from laptops, desktops and the latest generation of mobile devices such as iPhones and iPads using Epson's free iPrint app.
Print photos, iron-on transfers, CDs and more
A wide range of printing projects can be undertaken with the 1500W, which prints on glossy paper, plain paper, envelopes, iron-on transfers plus CDs and DVDs. Standard 4 x 6 inch (10 x 15cm) photos all the way up to panoramic and A3+ prints are supported.
Glossy, long-lasting prints
The 1500W uses Epson’s Claria 6-colour, dye-based ink-set to achieve vivid and long-lasting results with a glossy finish. Coupled with the resolution up to of 5760 x 1440dpi and small 1.5pl droplet size, this yields high-quality prints with fine detail and smooth tonal gradations.
The Stylus Photo 1500W can print from anywhere thanks to built-in Wi-Fi support, allowing convenient and easy printing from laptops, desktops and the latest generation of mobile devices such as iPhones and iPads using Epson's free iPrint app. -
A wide range of printing projects can be undertaken with the 1500W, which prints on glossy paper, plain paper, envelopes, iron-on transfers plus CDs and DVDs. Standard 4 x 6 inch (10 x 15cm) photos all the way up to panoramic and A3+ prints are supported. -
The 1500W uses Epson’s Claria 6-color, dye-based ink-set to achieve vivid and long-lasting results with a glossy finish. Coupled with the resolution up to of 5760 x 1440dpi and small 1.5pl droplet size, this yields high-quality prints with fine detail and smooth tonal gradations.
- Epson Stylus Photo 1500W - printer - colour - ink-jet
- Printer Type
- Photo printer - ink-jet - colour
- 11.8 kg
- Inkjet Technology
- Epson Micro Piezo
- Ink Palette Supported (Colours)
- 6-ink - cyan, magenta, yellow, black, light cyan, light magenta
- Max Media Size
- A3 plus (329 x 423 mm)
- Print Speed
- Up to 3.3 min/page - photo - A3 plus (329 x 423 mm) , Up to 0.75 min/page - photo - 100 x 150 mm
- Max Resolution (B&W)
- 5760 x 1440 dpi
- Max Resolution (Colour)
- 5760 x 1440 dpi
- Print on CD/DVD
- Interface
- USB, Wi-Fi(n), USB host
- Media Type
- Envelopes, plain paper, glossy photo paper, CD/DVD labels
- Total Media Capacity
- 100 sheets
- Networking
- Print server - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Apple MacOS X 10.4.11 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 61.6 cm x 32.2 cm x 21.5 cm
- Printer Type
Printer
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 6 x 90 nozzles
- Minimum Ink Droplet Size
- 1.5 pl
- Ink Cartridge Configuration
- 6 individual ink tanks
- Ink Type
- Epson Claria Photographic Ink
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 5760 x 1440 dpi
- 5760 x 1440 dpi
- Print on CD/DVD
- Direct Printing Specifications
- PictBridge
Media Handling
- Media Type
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), A6 (105 x 148 mm), 100 x 150 mm, A3 plus (329 x 423 mm), 130 x 180 mm, 90 x 130 mm, CD (120 mm), CD (80 mm), 200 x 250 mm, 130 x 200 mm
- Envelope Sizes
- International DL (110 x 220 mm), International C6 (114 x 162 mm), Com-10 (105 x 241 mm)
- Max Printing Width
- 329 mm
- Max Printing Length
- 1117 mm
- 100 sheets
- Media Feeders
- 1 x automatic - 100 sheets
- Networking
- Print server
- Data Link Protocol
- WEP, WPA-PSK, TKIP, AES
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x direct print port - USB 2.0 - 4 pin USB Type A
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 18 Watt
- Power Consumption Stand by / Sleep
- 3.5 Watt
- Software Included
- EPSON Print CD, EPSON Easy Photo Print, Epson iPrint 2.0
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- Sound Emission (Operating)
- 45 dBA
- 61.6 cm
- 32.2 cm
- 21.5 cm
- 11.8 kg
- Width (Shipping)
- 70.7 cm
- Depth (Shipping)
- 43.9 cm
- Height (Shipping)
- 31.8 cm
- Weight (Shipping)
- 12.1 kg
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £14.96 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.37 |
Epson A4 Iron On Transfer Pack 10sht | In Stock | £13.23 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.37 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £14.69 |
Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) | In Stock | £14.09 |
Epson Premium - Semi-gloss photo paper - Super A3 (330 x 483 mm) - 20 sheet(s) | In Stock | £21.42 |
Epson A3 Matte Paper Heavyweight 50 sheets | In Stock | £29.33 |
