Epson Replacement Lamp for EB-4550 Projector
Quicklinx: 9CKKWS00 Mfr#: v13h010l77
£151.66 ex VAT
£181.99 inc VAT
The genuine Epson ELPLP77 ultra high efficiency (UHE) projector lamp is designed to replace the original genuine Epson projector lamp included with the Epson PowerLite projectors.
  • Enhanced brightness
    The UHE lamp type in the Epson ELP LP77 projector lamp ensures your presentations are vivid and bright, suitable for any setting, from classrooms to boardrooms.
  • Seamless compatibility
    Designed specifically for PC use, this projector lamp integrates smoothly with your existing setup, ensuring a hassle-free experience whether you're presenting or streaming.
Epson ELPLP77 - projector lamp
Projector lamp - UHE
Epson EB-1970W, EB-1975W, EB-1980WU, EB-1985WU, EB-4550, EB-4650, EB-4750W, EB-4770W, EB-4850WU, EB-4950WU; PowerLite 4650, 4750W, 4855WU
Projector lamp
Lamp
UHE
Epson EB-1970W, EB-1975W, EB-1980WU, EB-1985WU, EB-4550, EB-4650, EB-4750W, EB-4770W, EB-4850WU, EB-4950WU , Epson PowerLite 4650, 4750W, 4855WU
Brand: Epson
