Start making moves that make a difference
Pulsense is the next generation heart rate and activity monitor. It measures heartbeat and activity 24 hours a day, tracking your steps, distance, calories, sleep quality, heart rate zones and more.
Built-in Heart Rate Sensor
Epson’s optical heart rate sensor is compact and energy-efficient, accurately reading heart rate from the back of your wrist, measuring the small changes in reflected light as blood passes through vessels in your skin. Measurement data derived from heart rate is more accurate than an accelerometer alone.
Continuously monitor your Heart Rate and Activity 24hrs a day
With 36 hours of battery life while continuously monitoring heart rate means you can truly monitor 24 hours of accurate data. Unlike some heart rate monitors, you can continue to record data, even while exercising. Pulsense will track heart rate while running at speeds of up to 15 kilometres per hour, measuring activity across five heart rate zones, simply displayed with LED lights.
Heart Rate based Sleep Cycle Tracking and Wake-up Alarm
Pulsense monitors the quality of your sleep from body movements and heart rate. When the accelerometer is still and your heart rate falls below a certain level Pulsense will automatically start to track your sleep patterns and quality. The sleep phase alarm wakes you up at the optimal time, so you can start your day the right way.
Heart Rate based Calorie Tracking
Pulsense calculates calories burned based upon body motion and heart rate. Your body burns more calories as you exercise. Your heart rate increases as your body demands more oxygen and fuel. This close relationship between heart rate and calories burned enables more detailed and accurate calorie calculations.
Set Targets and Review Progress
The Pulsense View app not only helps interpret your data, but will also, based on the goals you enter, set daily targets based on calorie intake from food and drink, calories burned by exercise and amount of time to exercise in the fat burning zone. Guiding you towards your targets. You can even enter your weight over time and Pulsense will predict your future progress.
Everything counts
Pulsense is a next generation 24-hour heart rate and activity monitor, tracking your steps, calories, sleep quality, heart rate zones and more.
- Epson PULSENSE PS-100B Medium/Large activity tracker - black
- Product Type
- Activity tracker
- Tracking Data
- Distance, time, calories burned, activity, sleep activity, heart rate, steps taken, weight
- Connectivity
- Bluetooth
- Notifications
- Calendar, Email
- Training zone
- Battery
- Lithium polymer - 40 mAh
- Battery Run Time
- Up to 36 hours
- Black
- 22 mm x 12.5 mm
- Length
- 150 mm - 210 mm
- 31 g
- 1-year warranty
- Product Type
- Activity tracker
- Notifications
- Calendar, Email
- Tracking Data
- Black
- Sensors
- Accelerometer, heart rate
- Training zone
- Wireless Interface
- Bluetooth 4.0
- Technology
- Lithium polymer
- Capacity
- 40 mAh
- Run Time (Up To)
- 36 hours
- 22 mm
- 12.5 mm
- Length
- 150 mm - 210 mm
- 31 g
- Preloaded Software
- Alarm
- System Requirements for PC Connection
- Microsoft Windows Vista SP2, Microsoft Windows 7 SP1, Windows 8, Windows 8.1
- Vibrating Alert
- Protection
- Waterproof
- Included Accessories
- Charging cradle
- Warranty
- 1-year warranty
