Epson Perfection V800 Photo Scanner A4 Flatbed Scanner
Quicklinx: B3F3WS00 Mfr#: B11B223401BY
Type: Flatbed scanner
Form Factor: Desktop
Max Paper Size: A4 (210 x 297 mm)
Interface: USB 2.0
Compatibility: Mac, PC
Hurry, only 3 left in stock!
£475.34 ex VAT
£570.40 inc VAT
Choice of resolution
The V800 features a dual lens system that automatically selects the optimal lens, with up to 4800dpi optical resolution for reflective photo scanning and 6400dpi when scanning using film holders.
Scan from any source
Scan 35mm strips and slides as well as medium format and 4x5 inch large format film in sharp focus thanks to the improved film holders with their adjustable height control and rigid design. The V800 also supports non-standard film formats up to 8x10 inch when placed directly on the scanner glass.
Cleans-up images
Digital ICE technologies automatically removes imperfections such as dust, hair, scratches and fingerprints from both film and photos to restore images to their former glory with the minimum of effort.
The right tone
Take advantage of excellent tone reproduction with 4.0 DMax optical density.The V800 can detect the exact tonal range of the original, making sure the brightest and darkest areas of images are accurately reproduced to reveal impressive detail and dynamic range.
Advanced software
As well as Epson Scan, the V800 comes with SilverFast SE 8 software for advanced scanning features.
Save time
Epson's ReadyScan technology features an LED light source with a warm-up time of less than one second, so scanning can start almost instantly. With a very low power consumption it saves energy too.
  • Film and photo scanner
    Perfect for helping life-long photo enthusiasts and photographers convert their film and images into high-quality digital media.
Epson Perfection V800 Photo - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Light Source
White LED
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
48-bit colour
Optical Resolution
6400 dpi x 9600 dpi
Interpolated Resolution
12800 dpi x 12800 dpi
Max Document Size
216 mm x 297 mm
Supported Document Type
Plain paper, film, photo
Document Feeder Type
Automatic
AC 230V (50 - 60 Hz)
Microsoft Windows 7, Microsoft Windows XP SP2 or later, Microsoft Windows Vista, Apple MacOS X 10.6.8 or later, Windows 8, Windows 8.1
50.3 cm x 30.8 cm x 15.2 cm
6.6 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
A4 (210 x 297 mm)
Scanner
Input Type
Colour Depth
48-bit colour
Colour Depth (External)
48-bit colour
Optical Resolution
6400 dpi x 9600 dpi
Scan Element Type
CCD
Bulb / Light Source Type
White LED
Scan Density Range
4.0D
Scanner Speed Details
12 sec/scan - draft - A4 , 15 sec/scan - best - A4 , 6 sec/scan - preview - A4 , 67 sec/scan - film (negatives) - 35mm - 4800 dpi , 37 sec/scan - film (negatives) - 35mm - 2400 dpi , 70 sec/scan - film (positives) - 35mm - 4800 dpi , 40 sec/scan - film (positives) - 35mm - 2400 dpi
Scanner Features
Digital ICE Technology, Dual Lens System, EPSON ReadyScan LED Technology, Backlight Correction, Noise Reduction, Grain Correction
Media Handling
Max Document Size
216 mm x 297 mm
Automatic
USB 2.0 - Type B
4 film holders
1 x USB cable
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
23 Watt
Power Consumption Stand by
12 Watt
Power Consumption Sleep
1.5 Watt
Software Included
Drivers & Utilities, EPSON Scan, EPSON Event Manager, EPSON Copy Utility, LaserSoft Imaging SilverFast SE 8
50.3 cm
30.8 cm
15.2 cm
6.6 kg
5 °C
35 °C
10 - 80%
Interface: USB 2.0
Compatibility: Mac
Compatibility: PC
Brand: Epson
Price Range Ex VAT: 300 - 500
