Epson Perfection V600 A4 colour flatbed scanner
Epson V600 Scanner
Quicklinx: 70NYWS00 Mfr#: B11B198031
Type: Flatbed scanner
Form Factor: Desktop
Max Paper Size: 216 x 297 mm
Interface: USB 2.0
Compatibility: Mac, PC
Hurry, only 2 left in stock!
£218.71 ex VAT
£262.45 inc VAT
Scan all your prints, negatives and slides quickly and efficiently. Complete with film holders it handles just about any size and format, including 35 mm filmstrips, mounted slides and full panoramic medium format film.
Advanced DIGITAL ICE technologies make it easy to remove dust and scratches from film and photos, and you can check every detail in your images with the resizable preview window.
Featuring Epson ReadyScan LED technology, you can start scanning instantly with no warm-up time. You also use less energy when you scan, which is better for the environment and also saves you money.
And whatever you scan you can be sure of capturing every detail with high-quality 6400 dpi optical resolution with Epson Matrix CCD technology.
  • Home photo scanner
    Remove dust and scratches with this versatile, 6400 dpi scanner, featuring advanced DIGITAL ICE technologies for both film and photos.
Epson Perfection V600 Photo - flatbed scanner
Flatbed scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Light Source
White LED
Max Supported Document Size
216 x 297 mm
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
Optical Resolution
6400 dpi x 9600 dpi
Interpolated Resolution
12800 dpi x 12800 dpi
Max Document Size
216 mm x 297 mm
Supported Document Type
Transparencies, plain paper, slides, bulk objects (such as books), film
Document Feeder Type
Manual, automatic (optional)
AC 120/230 V ( 50/60 Hz )
Microsoft Certification
Compatible with Windows 7
28 cm x 48.5 cm x 11.8 cm
4 kg
1 year warranty
Interface Type
USB 2.0
216 x 297 mm
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
48-bit colour
Optical Resolution
6400 dpi x 9600 dpi
Scan Element Type
CCD
Bulb / Light Source Type
White LED
Scan Density Range
3.4D
Control Panel Buttons Functions
Copy, start, Scan-to-Email, Scan-to-PDF
Scanner Features
Digital ICE Technology, EPSON ReadyScan LED Technology
Media Handling
Max Document Size
216 mm x 297 mm
Supported Document Size Details
Flatbed - up to 216 x 297 mm , Film - up to film 135 (35mm) - 12 frames (strip) , Slide - up to film 135 (35mm) - 4 frames (mounted)
USB 2.0 - Type B
Film adaptor, slide holder
1 x USB cable
External power adapter
Power Consumption Operational ( Standby )
16.5 Watt ( 1.6 Watt )
Software Included
ASF Digital ICE, ABBYY FineReader 5.0 Sprint Plus, Epson Scan 3.8, ABBYY FineReader 6.0 Sprint Plus, EPSON Event Manager, EPSON Copy Utility
28 cm
48.5 cm
11.8 cm
4 kg
1 year warranty
Service & Support Details
Limited warranty - 1 year
10 °C
35 °C
10 - 80%
Interface: USB 2.0
Compatibility: Mac
Compatibility: PC
Brand: Epson
Price Range Ex VAT: 150 - 300
