Epson Perfection V550 Photo
Quicklinx: 8X01WS00 Mfr#: B11B210301
Type: Flatbed scanner
Form Factor: Desktop
Max Paper Size: A4 (210 x 297 mm)
Interface: USB 2.0
Compatibility: Mac, PC
29 in stock
£186.30 ex VAT
£223.56 inc VAT
Fast, high-quality scanning
Thanks to Epson Matrix CCD technology and an optical resolution of 6,400dpi, every detail is faithfully captured. With fast, energy-efficient Epson ReadyScan LED technology, there's virtually no warm-up time, so you can start scanning your photos and films almost instantly.
Restore old photos
With Digital ICE Technology, damaged film can be digitally repaired without the need for time-consuming retouching. Imperfections, scratches and fingerprints are all removed from scanned film automatically. In addition, Epson Easy Photo Fix restores faded colour, removes the appearance of dust and adjusts backlight to bring your old photos back to life.
Negatives to digital
The built-in transparency unit allows you to scan two 35mm filmstrips (12 frames) or four 35mm mounted slides at a time and also supports medium format film. You can also scan up to A2-sized pages, such as large photos, newspaper articles, posters etc. with ArcSoft Scan 'n' Stitch Deluxe software .
Scan to cloud
Epson Easy Photo Scan enables direct scanning to selected social media and photo sharing websites, as well as other cloud storage services. You can access your photos from almost anywhere and share with friends and family.
Energy saving
With virtually no warm-up time and low energy consumption, this photo scanner can help reduce your energy bills and impact on the environment.
  • Photo scanner
    The photo scanner that quickly transforms old, tired photos, film and slides into crisp, clear digital images.
Epson Perfection V550 Photo - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scan Element Type
CCD
Light Source
White LED
Max Supported Document Size
A4 (210 x 297 mm)
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
48-bit colour
Optical Resolution
6400 dpi x 9600 dpi
Interpolated Resolution
12800 dpi x 12800 dpi
Max Document Size
216 mm x 297 mm
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5.8 or later, Windows 8
Microsoft Certification
Compatible with Windows 7
28 cm x 48.5 cm x 11.8 cm
4.1 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
A4 (210 x 297 mm)
Scanner
Colour Depth
48-bit colour
Colour Depth (External)
48-bit colour
Optical Resolution
6400 dpi x 9600 dpi
Scan Element Type
CCD
Bulb / Light Source Type
White LED
Scan Density Range
3.4D
Scanner Features
Digital ICE Technology, EPSON ReadyScan LED Technology, Backlight Correction
Media Handling
Max Document Size
216 mm x 297 mm
USB 2.0 - Type B
ENERGY STAR Certified
Software Included
EPSON Scan, ArcSoft Scan-n-Stitch Deluxe, EPSON Event Manager, EPSON Copy Utility, ABBYY FineReader 9.0 Sprint, ABBYY FineReader 8.0 Sprint for MAC
28 cm
48.5 cm
11.8 cm
4.1 kg
Limited warranty - 1 year - carry-in
10 °C
35 °C
10 - 80%
Interface: USB 2.0
Compatibility: Mac
Compatibility: PC
Brand: Epson
Price Range Ex VAT: 150 - 300
