Epson Perfection V39 Scanner
Quicklinx: BKXFWS00 Mfr#: B11B232401
Type: Flatbed scanner
Form Factor: Desktop
Max Paper Size: A4 (210 x 297 mm)
Interface: USB 2.0
Compatibility: Mac, PC
33 left in stock
£72.02 ex VAT
£86.42 inc VAT
Ultra-compact and tidy
The V39's power and connectivity is handled via a single Micro USB to reduce cable clutter and keep your workspace tidy. The device also has a built-in stand for flexible scanning to suit your desk space.
Fast, high-quality results
Thanks to Epson's ReadyScan LED Technology, you can start scanning instantly - no warm-up time is required. Make sure that even your old photos look their best with Epson Easy Photo Fix software, which improves the quality of your scans by removing dust, restoring faded colours and correcting backlight. Even your scanned documents will look great as the V39 comes with a range of enhancement features, enabling you to improve text sharpness and remove unwanted 'bleed-through' from double-sided documents.
Convenient
To make scanning quick and easy, the V39 has four one-touch buttons so you can scan, copy, share and turn your photos and documents into multi-page searchable PDFs at the push of a button. For added versatility, a fully-detachable lid makes scanning of thick books, photo albums and other bound items possible. Thanks to clever software the V39 can even handle larger photos and documents - simply scan the large item in A4 sections and then seamlessly join the sections back together to create the whole image . Scan directly to cloud storage services such as SugarSync and Evernote and easily share your photos with family and friends by scanning straight to Facebook and Picasa.
Epson Perfection V39 - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Contact Image Sensor (CIS)
Light Source
White LED
Additional Functions
Scan to cloud
Max Supported Document Size
A4 (210 x 297 mm)
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
24-bit (16.7 million colours)
Optical Resolution
4800 dpi x 4800 dpi
Interpolated Resolution
6400 dpi x 6400 dpi
Max Document Size
216 mm x 297 mm
Supported Document Type
Plain paper
Document Feeder Type
Manual
Microsoft Windows 7, Microsoft Windows XP SP2 or later, Microsoft Windows Vista, Apple MacOS X 10.7.x, Windows 8, Apple MacOS X 10.6.8, Apple MacOS X 10.8.x, Windows 8.1, Apple MacOS X 10.9.x
24.9 cm x 36.4 cm x 3.9 cm
1.5 kg
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Interface Type
USB 2.0
Scan to cloud
A4 (210 x 297 mm)
Scanner
Input Type
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
4800 dpi x 4800 dpi
6400 dpi x 6400 dpi
Scan Element Type
Bulb / Light Source Type
White LED
Control Panel Buttons Functions
Copy, start, send to, PDF
Scanner Speed Details
10 sec/scan - black & white - A4 - 300 dpi , 10 sec/scan - colour - A4 - 300 dpi , 12 sec/scan - black & white - A4 - 600 dpi , 29 sec/scan - colour - A4 - 600 dpi
Scanner Features
Backlight Correction, Text Enhancement, RGB Color Dropout, A2 stitching
Media Handling
Max Document Size
216 mm x 297 mm
Plain paper
Manual
USB 2.0 - Type AB
Stand
1 x USB cable
ENERGY STAR Certified
Power Consumption Operational (Standby)
2.5 Watt
Power Consumption Stand by
1.1 Watt
Software Included
EPSON Scan, ArcSoft Scan-n-Stitch Deluxe, EPSON Copy Utility, EPSON Document Capture Pro, EPSON Easy Photo Scan, EPSON Document Capture
24.9 cm
36.4 cm
3.9 cm
1.5 kg
Limited warranty - 1 year - carry-in
10 °C
35 °C
20 - 80%
Interface: USB 2.0
Compatibility: Mac
Compatibility: PC
Brand: Epson
Stock Status: Clearance
Price Range Ex VAT: 50 - 100
