Epson LX 300+II Colour Dot-Matrix Printer
Quicklinx: B70VWS00 Mfr#: C11C640041A5
There is a new High-Speed Draft mode that delivers an astonishing 337 characters per second! An even bigger surprise is that the LX-300+II is still one the quietest printers in its class.
It out-performs its predecessor with a new bottom-feed paper path that's ideal for handling complex, multi-page forms. Even on multi-page forms that are five layers thick, the LX-300+II delivers crisp, clean printouts to the very last page.
  • Speed
  • Paper handling
Epson LX 300+II Colour - printer - B/W - dot-matrix
Printer Type
Personal printer - dot-matrix - 9 pin - B/W
4.4 kg
Print Speed
Up to 300 char/sec - high speed draft , Up to 225 char/sec - draft , Up to 56 char/sec - near letter , Up to 270 char/sec - draft , Up to 67 char/sec - near letter , Up to 337 char/sec - high speed draft
Parallel, USB, serial
RAM Installed (Max)
64 KB
Language Simulation
EPSON ESC/P, IBM 2380 Plus
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Media Type
Envelopes, labels, plain paper, continuous forms
Microsoft Windows 98, Microsoft Windows 2000, Microsoft Windows XP
1-year warranty
36.6 cm x 27.5 cm x 15.9 cm
Printer Type
Personal printer - dot-matrix - 9 pin - monochrome
Printer
Print Speed
Up to 300 char/sec - high speed draft - 10 cpi , Up to 225 char/sec - draft - 10 cpi , Up to 56 char/sec - near letter - 10 cpi , Up to 270 char/sec - draft - 12 cpi , Up to 67 char/sec - near letter - 12 cpi , Up to 337 char/sec - high speed draft - 12 cpi
Wired
Language Simulation
Fonts Included
8 x barcode
Barcodes
RAM
RAM Installed (Max)
64 KB
Media Handling
Media Type
Media Sizes
A4 (210 x 297 mm)
Max Sheets in Multi-Part Form
5
1 x parallel - 36 PIN Centronics , 1 x RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin USB Type B
Colour upgrade kit
Consumables Included
1 x ribbon (black) - up to 3 million characters
MTBF
6,000 hour(s)
Power supply - internal
23 Watt
Software Included
EPSON Status Monitor
Limited warranty - 1 year - carry-in
5 °C
35 °C
10 - 80%
Sound Emission (Operating)
49 dBA
36.6 cm
27.5 cm
15.9 cm
4.4 kg
