Reliable performance:
This printer is built to last, with a mean volume between failure of 40 million lines, a mean 'time between failure' of 20,000 power-on hours and a print head life of 400 million strokes per wire. The ribbon matches up to the other hardware, with a life of up to 5 million characters.
Take your pick:
Choose the way you work with a range of cut-sheet or continuous paper handling combinations that suits the demands of any office or warehouse.
Fits right in:
Get set up quickly with standard USB and parallel and optional serial, Twinax and Coax interfaces. Expand access with optional wired networking.
This printer is built to last, with a mean volume between failure of 40 million lines, a mean 'time between failure' of 20,000 power-on hours and a print head life of 400 million strokes per wire. The ribbon matches up to the other hardware, with a life of up to 5 million characters. -
Take your pick
Choose the way you work with a range of cut-sheet or continuous paper handling combinations that suits the demands of any office or warehouse. -
Fits right in
- Epson LQ 590 - printer - B/W - dot-matrix
- Printer Type
- Workgroup printer - dot-matrix - 24 pin - B/W
- 7.1 kg
- Max Media Size
- 254 x 559 mm, JIS B4 (257 x 364 mm), continuous paper 101.6 mm - 254 mm (width)
- Max Media Size (Custom)
- 257 mm x 364 mm
- Print Speed
- Up to 440 char/sec - fast draft , Up to 529 char/sec - fast draft , Up to 330 char/sec - draft , Up to 396 char/sec - draft , Up to 495 char/sec - draft , Up to 110 char/sec - letter , Up to 132 char/sec - letter , Up to 165 char/sec - letter
- Interface
- Parallel, USB
- RAM Installed (Max)
- 128 KB
- Barcodes
- Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
- Media Type
- Envelopes, plain paper, continuous forms
- System Requirements
- Microsoft Windows 95/98/ME/NT/2000/XP
- Microsoft Certification
- Works with Windows Vista
- 1-year warranty
- 43.7 cm x 37.5 cm x 17.1 cm
- Printer Type
- Workgroup printer - dot-matrix - 24 pin - monochrome
Printer
- Print Speed
- Up to 440 char/sec - fast draft - 10 cpi , Up to 529 char/sec - fast draft - 12 cpi , Up to 330 char/sec - draft - 10 cpi , Up to 396 char/sec - draft - 12 cpi , Up to 495 char/sec - draft - 15 cpi , Up to 110 char/sec - letter - 10 cpi , Up to 132 char/sec - letter - 12 cpi , Up to 165 char/sec - letter - 15 cpi
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- Columns
- 80
- Fonts Included
- 10 x bitmapped , 4 x scalable , 8 x barcode
- Barcodes
RAM
- 128 KB
Media Handling
- Media Type
- Max Media Size
- 257 mm x 364 mm
- Media Sizes
- JIS B4 (257 x 364 mm), 100 x 100 mm
- Media Thickness Range
- 0.065 mm - 0.39 mm
- Connections
- 1 x parallel , 1 x USB
- MTBF
- 20,000 hour(s)
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Power Device
- Power supply - internal
- Frequency Required
- 50 - 60 Hz
- 42 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 10 - 80%
- Sound Emission (Operating)
- 51 dBA
- 43.7 cm
- 37.5 cm
- 17.1 cm
- 7.1 kg
Epson BLACK FABRIC RIBBON FOR LQ-590 | In Stock | £10.46 |
