Design labels easily
Creating labels is easy using the included software with intuitive menus. Choose from pre-loaded label templates, or design your own and store them on your computer. A special toolbar enables you to add pre-defined frames, symbols, barcodes and text enhancements, or import images. In just a few steps, your label is ready to print.
Import and print data
Using the software, you can import data in csv, txt and xls(x) formats, create a layout corresponding to the column headings, and then print labels for each line of data. You can also print a series of labels with incremental dates or figures.
Convenient
Producing labels is a hassle-free process from start to finish, as the LW-900P automatically detects the tape width, and automatically cuts or half-cuts the labels once printed. Its convenient integrated trimmer can round label edges, and a dedicated window displays how much tape remains.
Flexible tape options
Epson's wide selection of labels in 6, 9, 12, 18, 24 and 36mm sizes cover virtually every labelling need, with transparent labels, cable wraps, writable matte paper labels and more, plus a choice of adhesive strengths and colour combinations. All Epson labels are very durable, resisting water and withstanding hot and cold conditions.
Economical
The LW-900P minimises label margins, meaning you get more labels per tape, and Epson's 9-metre label tape offers economical refills. Two four-metre label tapes are included to get you started.
- Epson LabelWorks LW-900P - labelmaker - monochrome - thermal transfer
- Printer Type
- Labelmaker - thermal transfer - monochrome
- 0.9 kg
- Max Media Size
- Roll (3.6cm)
- Print Speed
- Up to 25 mm/sec
- Max Resolution (B&W)
- 360 dpi
- Interface
- USB
- Barcodes
- Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, PDF417, Data Matrix, ITF
- Styles & Effects
- Vertical, Mirror
- System Requirements
- Apple MacOS, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
- Microsoft Certification
- Compatible with Windows 7
- Enclosure Colour
- Pale grey
- 2 years warranty
- 18.2 cm x 8.5 cm x 14.6 cm
- Printer Type
- Enclosure Colour
- Pale grey
Printer
- Print Speed
- Up to 25 mm/sec
- Built-in Devices
- Cutter
- Connectivity Technology
- Wired
- Interface
- USB
- 360 dpi
- Styles & Effects
- Vertical, Mirror
- Auto Cutter
- Barcodes
Media Handling
- Max Media Size
- Roll (3.6cm)
- Media Sizes
- Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (3.6cm)
- Connections
- 1 x USB - 4 pin USB Type B
- Power Device
- Power adapter - external
- 13.6 Watt
- Power Consumption Stand by / Sleep
- 0.7 Watt
- Software Included
- Epson Label Editor
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 2 years
- 18.2 cm
- 8.5 cm
- 14.6 cm
- 0.9 kg
