The LW-400VP is straightforward to use and ideal for busy work environments away from the office. Dedicated buttons give quick access to cutting and printing functions, while an internal memory allows you to save and recall your favourite 50 label designs at any time.
The smart, black design helps keep the label maker free from smears and fingerprints, while its black rubber casing provides a protective barrier against scratches and drops. Its black sturdy carry case enables you to transport it easily and safely, and gives you room to take the AC adaptor and up to six tapes with you.
The LW-400VP minimises label margins, meaning you get more labels per tape, and Epson's nine-metre label tape offers economical refills. You don't need to replace tapes quite so often. Two four-metre label tapes are included to get you started – black text on standard white tape, 12mm wide, and black text on strong adhesive yellow tape, 9mm wide.
The label maker prints up to four lines and offers excellent versatility thanks to a large number of formats, symbols and font designs. You can see how your labels will look – even in darkness or bright sunlight – thanks to the LW-400VP's backlit LCD screen.
- Epson LabelWorks LW-400VP - labelmaker - B/W - thermal transfer
- Printer Type
- Labelmaker - thermal transfer - B/W
- Form Factor
- Portable
- 418 g
- Max Media Size
- Roll (1.8 cm)
- Print Speed
- Up to 6 mm/sec
- Max Resolution (B&W)
- 180 dpi
- Cutter
- Barcodes
- Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, ITF
- Fonts
- Sans Serif, Gothic
- Styles & Effects
- Bold, italic bold, italic outline, italic shadow, normal, vertical, outline, shadow, italic, Mirror
- 4 line printing
- Display Resolution
- 2 lines x 16 characters
- Keyboard
- QWERTY / 61 keys
- Battery
- Required 6 x AA type
- Enclosure Colour
- Black, green
- 2-year warranty
- 17 cm x 11 cm x 5.6 cm
- Printer Type
- Labelmaker - thermal transfer - monochrome
- Enclosure Colour
- Black, green
Printer
- Print Speed
- Up to 6 mm/sec
- Built-in Devices
- Preview screen, character keyboard
- 180 dpi
- Fonts
- Styles & Effects
- 4 line printing
- Cutter
- Keyboard
- QWERTY / 61 keys
- Repeating Printing
- 9 copies
- Barcodes
Media Handling
- Max Media Size
- Roll (1.8 cm)
- Media Sizes
- Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm)
- Max Printing Width
- 9 mm
- Max Printing Length
- 400 mm
- Included Accessories
- Carrying case
- Media Included
- 1 12 mm x 4 m black on white LC tape, 1 9 mm x 4 m black on yellow strong adhesive LC tape
- Power Device
- Power adapter - external
- 2.555 Watt
- Power Consumption Stand by / Sleep
- 0.18 Watt
- AA type
- Required Qty
- 6
Environmental Standards
- ENERGY STAR
- Limited warranty - 2 years - carry-in
- 17 cm
- 11 cm
- 5.6 cm
- 418 g
