With its ergonomic buttons and integrated keyboard, the LW-400 is straightforward to use. Dedicated buttons give quick access to cutting and printing functions, while an internal memory allows you to save and recall your favorite label designs at any time. Remaining tape can be checked via a window.
Straightforward to use
With its ergonomic buttons and integrated keyboard, the LW-400 is straightforward to use. Dedicated buttons give quick access to cutting and printing functions, while an internal memory allows you to save and recall your favourite 50 label designs at any time. Remaining tape can be checked via a window.
Versatile
The LW-400 prints up to four lines and offers excellent versatility with eight barcode standards, 14 fonts, five character sizes, 487 symbols, 87 borders and 10 styles, including bold, italic, outline and shadow. See how your labels will look - even in darkness or sunlight - thanks to the LW-400's backlit LCD screen.
Flexible tape options
Epson's wide selection of labels in 6, 9, 12 and 18mm sizes cover virtually every labelling need. The range includes standard, black, transparent and writable matte paper labels, a variety of colours such as fluorescent and pastel, and two adhesive strengths. All Epson labels are durable, resisting water and withstanding hot and cold conditions.
Economical
The LW-400 minimises label margins, meaning you get more labels per tape, and Epson's 9-metre label tape offers economical refills. Two four-metre label tapes are included to get you started.
Backlit screen
For all light conditions
Flexible formatting
Choice of fonts, styles and borders
Choice of tapes
6, 9, 12 and 18mm labels
Store 50 designs
Create and save custom designs
9-metre tapes
For economical refills
With its ergonomic buttons and integrated keyboard, the LW-400 is straightforward to use. Dedicated buttons give quick access to cutting and printing functions, while an internal memory allows you to save and recall your favourite 50 label designs at any time. Remaining tape can be checked via a window. -
Versatile
The LW-400 prints up to four lines and offers excellent versatility with eight barcode standards, 14 fonts, five character sizes, 487 symbols, 87 borders and 10 styles, including bold, italic, outline and shadow. See how your labels will look - even in darkness or sunlight – thanks to the LW-400's backlit LCD screen. -
Epson's wide selection of labels in 6, 9, 12 and 18mm sizes cover virtually every labelling need. The range includes standard, black, transparent and writable matte paper labels, a variety of colours such as fluorescent and pastel, and two adhesive strengths. All Epson labels are durable, resisting water and withstanding hot and cold conditions. -
Economical
- Epson LabelWorks LW-400 - labelmaker - B/W - thermal transfer
- Printer Type
- Labelmaker - thermal transfer - B/W
- Form Factor
- Portable
- 420 g
- Max Media Size
- Roll (1.8 cm)
- Print Speed
- Up to 6 mm/sec
- Max Resolution (B&W)
- 180 dpi
- Cutter
- Barcodes
- Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, ITF
- Fonts
- Sans Serif, Gothic
- Styles & Effects
- Bold, italic bold, italic outline, italic shadow, normal, vertical, outline, shadow, italic, Mirror
- 4 line printing
- Display Resolution
- 2 lines x 16 characters
- Keyboard
- 61 keys
- Battery
- Required 6 x AAA type
- 2-year warranty
- 11 cm x 17 cm x 5.6 cm
- Printer Type
- Labelmaker - thermal transfer - monochrome
Printer
- Print Speed
- Up to 6 mm/sec
- Built-in Devices
- Preview screen, character keyboard
- 180 dpi
- Fonts
- Styles & Effects
- 4 line printing
- Cutter
- Keyboard
- 61 keys
- Repeating Printing
- 9 copies
- Barcodes
Media Handling
- Max Media Size
- Roll (1.8 cm)
- Media Sizes
- Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm)
- Max Printing Width
- 9 mm
- Max Printing Length
- 400 mm
- Power Device
- Power adapter - external
- 2.26 Watt
- Power Consumption Stand by / Sleep
- 0.18 Watt
- AAA type
- Required Qty
- 6
Environmental Standards
- ENERGY STAR
- Limited warranty - 2 years
- 11 cm
- 17 cm
- 5.6 cm
- 420 g
