High-quality productivity: The GT-S85 produces high-quality scans at speeds of up to 40 pages per minute in simplex or 80 images per minute in duplex, in mono and colour, at 200dpi. Double-sided pages are scanned in a single pass, while a 75-sheet automatic document feeder is perfect for large-volume jobs. For extra reliability, an ultrasonic sensor is fitted to detect and easily recover paper jams.
Easy to integrate: Designed to fit into virtually any document management system, the GT-S85 is fully compatible with complex IT environments such as Windows Service OS and Citrix.
Simplify tasks: Complicated jobs, such as organising documents and reports, converting business cards into a database or enhancing text, become effortless thanks to Epson's advanced software and imaging technology. Customise up to 10 'scan to job' functions to scan and send files where you want them with just a single touch of a button.
Eco-friendly: Epson ReadyScan LED technology means no warm-up time and lower power consumption, reducing costs and environmental impact. The GT-S85 is also a mercury-free product, making it more environmentally-conscious.
High-performance scanning
This high-speed, dependable, A4 sheetfed business scanner provides a complete document management package for demanding organisations.
- Epson GT S85 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- CCD
- Light Source
- LED
- Max Supported Document Size
- A4 (210 x 297 mm)
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels) / 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 40 ppm (mono) / 40 ppm (colour)
- Max Document Size
- 216 mm x 914 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, business card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 75 sheets
- Duty Cycle
- 3000 scans per day
- Power
- AC 230V (50 Hz)
- System Requirements
- Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Citrix Presentation Server 4.5, Apple MacOS X 10.3.9 - 10.6.x, Citrix XenDesktop 5.0, Citrix XenDesktop 6.0
- Microsoft Certification
- Compatible with Windows 7
- 30.3 cm x 20.2 cm x 21.3 cm
- 5 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1-year warranty
- Interface Type
- USB 2.0
- A4 (210 x 297 mm)
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- CCD
- Bulb / Light Source Type
- LED
- Max Document Scan Speed B/W
- 40 ppm
- Max Document Scan Speed Colour
- 40 ppm
- Duty Cycle
- Scanner Speed Details
- 40 ppm - black & white - A4 - 200 dpi , 40 ppm - colour - A4 - 200 dpi , 40 ppm - greyscale - A4 - 200 dpi , 80 ipm - duplex - black & white - A4 - 200 dpi , 80 ipm - duplex - colour - A4 - 200 dpi , 80 ipm - duplex - greyscale - A4 - 200 dpi
- Scanner Features
- EPSON ReadyScan LED Technology, Ultrasonic multifeed sensor
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 914 mm
- Automatic
- 75 sheets
- Interfaces Details
- USB 2.0 - Type B
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Device
- External power adapter
- Voltage Required
- AC 230V (50 Hz)
- Power Consumption Operational (Standby)
- 45 Watt (5 Watt)
- Software Included
- ABBYY FineReader 6.0 Sprint Plus, Presto! BizCard 5, Presto! PageManager 8 Professional, ABBYY FineReader 5.0 Sprint Plus for Mac, EPSON Event Manager 2.6, EPSON Event Manager 2.3, EPSON Copy Utility 3.5, Presto! BizCard 5.6, EPSON Scan 3.67, EPSON Scan 3.65
- OS Required
- 30.3 cm
- 20.2 cm
- 21.3 cm
- 5 kg
- Limited warranty - 1 year - on-site
- 5 °C
- 35 °C
- 10 - 80%
