The Epson FX-890II Series offers the durability and ease of use for critical daily print requirements. These reliable 9-pin, narrow-carriage impact printers boast a long life cycle, and high speeds. Their ribbon cartridge reduces user interventions as well as cost per page. Ideal for harsh environments, these workhorses race through cut-sheet, continuous or multipart forms up to 7 pages thick, and feature an intuitive control panel for easy setup and operation.
Low-TCO dot matrix printer
Nine-pin dot matrix printer offering faster printing, outstanding reliability and extremely low TCO.
- Epson FX 890II - printer - B/W - dot-matrix
- Printer Type
- Workgroup printer - dot-matrix - 9 pin - B/W
- 7.2 kg
- Max Media Size
- Roll (21.6 cm), JIS B4 (257 x 364 mm), continuous paper 101.6 mm - 254 mm (width)
- Print Speed
- Up to 738 char/sec - ultra high speed draft , Up to 615 char/sec - ultra high speed draft , Up to 694 char/sec - high speed draft , Up to 612 char/sec - high speed draft , Up to 555 char/sec - draft , Up to 463 char/sec - draft , Up to 138 char/sec - letter , Up to 115 char/sec - letter
- Max Resolution (B&W)
- 240 x 144 dpi
- Interface
- Parallel, USB 2.0
- RAM Installed (Max)
- 128 KB
- Language Simulation
- EPSON ESC/P, IBM PPDS
- Barcodes
- Matrix 2 of 5, Industrial 2 of 5, Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Interleaved 2 of 5, Postnet
- Media Type
- Envelopes, plain paper, continuous forms
- System Requirements
- Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016
- 41.4 cm x 32 cm x 17.65 cm
- Printer Type
- Workgroup printer - dot-matrix - 9 pin - monochrome
Printer
- Print Speed
- Up to 738 char/sec - ultra high speed draft - 12 cpi , Up to 615 char/sec - ultra high speed draft - 10 cpi , Up to 694 char/sec - high speed draft - 12 dpi , Up to 612 char/sec - high speed draft - 10 cpi , Up to 555 char/sec - draft - 12 cpi , Up to 463 char/sec - draft - 10 cpi , Up to 138 char/sec - letter - 12 cpi , Up to 115 char/sec - letter - 10 cpi
- Connectivity Technology
- Wired
- Interface
- Parallel, USB 2.0
- 240 x 144 dpi
- Barcodes
RAM
- 128 KB
Media Handling
- Media Type
- Max Media Size
- Media Sizes
- Roll (21.6 cm), JIS B4 (257 x 364 mm), 100 x 100 mm, continuous paper 101.6 mm - 254 mm (width)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), US No 6 (92 x 165 mm)
- Media Thickness Range
- 0.06 mm - 0.46 mm
- Max Sheets in Multi-Part Form
- 6
- Connections
- 1 x USB 2.0 , 1 x parallel
- Consumables Included
- 1 x printhead - up to 400 million characters , 1 x ribbon (black) - up to 7.5 million characters
- MTBF
- 25,000 hour(s)
- EMC, ICES-003 Class A, UL 60950-1, FCC Part 15 B Class A, CAN/CSA-C22.2 No. 60950-1
- Power Device
- Power supply - internal
- Frequency Required
- 50 - 60 Hz
- 54 Watt
- Power Consumption Stand by
- 8 Watt
- Power Consumption Sleep
- 0.8 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- 5 °C
- 35 °C
- 10 - 80%
- Sound Emission (Operating)
- 55 dBA
- 41.4 cm
- 32 cm
- 17.65 cm
- 7.2 kg
