Epson FX 890 Mono Dot-Matrix Printer
Quicklinx: 65NPWS00 Mfr#: C11C524026
FX-890 dot matrix printer, 18 pins, 80 column, original + 6 copies(pull tractor), 566 cps UHSD (10 cpi), ESC/P, IBM PPDS , 16 fonts, 8 BarCode fonts, single sheet and continuous, 4 paper paths, paper park, USB and Parallel I/F, 1 slot for opt. Epson Type B I/F card.
Epson FX 890 - printer - B/W - dot-matrix
Printer Type
Workgroup printer - dot-matrix - 9 pin - B/W
7.2 kg
United Kingdom
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Print Speed
Up to 680 char/sec - max speed , Up to 566 char/sec - max speed , Up to 627 char/sec - fast draft , Up to 559 char/sec - fast draft , Up to 503 char/sec - draft , Up to 419 char/sec - draft , Up to 125.9 char/sec - letter , Up to 104.6 char/sec - letter
Parallel, USB
RAM Installed (Max)
128 KB
Barcodes
Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
Microsoft Windows 95/98, Microsoft Windows 2000 / NT4.0, Microsoft Windows Millennium Edition, Microsoft Windows XP
Microsoft Certification
Works with Windows Vista
1-year warranty
41.4 cm x 35 cm x 16.8 cm
Printer Type
Workgroup printer - dot-matrix - 9 pin - monochrome
United Kingdom
Printer
Print Speed
Up to 680 char/sec - max speed - 12 cpi , Up to 566 char/sec - max speed - 10 cpi , Up to 627 char/sec - fast draft - 12 cpi , Up to 559 char/sec - fast draft - 10 cpi , Up to 503 char/sec - draft - 12 cpi , Up to 419 char/sec - draft - 10 cpi , Up to 125.9 char/sec - letter - 12 cpi , Up to 104.6 char/sec - letter - 10 cpi
Wired
Parallel, USB
Fonts Included
3 x bitmapped , 8 x barcode
Barcodes
RAM
RAM Installed (Max)
128 KB
Media Handling
Media Size Class
A4
Max Media Size
A4 (210 x 297 mm)
Media Sizes
A4 (210 x 297 mm)
Max Sheets in Multi-Part Form
6
1 x USB , 1 x parallel
Consumables Included
1 x ribbon (black) - up to 7.5 million characters
MTBF
20,000 hour(s)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Software Included
EPSON Status Monitor 3
Limited warranty - 1 year
Sound Emission (Operating)
55 dBA
41.4 cm
35 cm
16.8 cm
7.2 kg
65NP Epson FC-890 Ribbon Cartridge In Stock £4.83
