FX-890 dot matrix printer, 18 pins, 80 column, original + 6 copies(pull tractor), 566 cps UHSD (10 cpi), ESC/P, IBM PPDS , 16 fonts, 8 BarCode fonts, single sheet and continuous, 4 paper paths, paper park, USB and Parallel I/F, 1 slot for opt. Epson Type B I/F card.
- Epson FX 890 - printer - B/W - dot-matrix
- Printer Type
- Workgroup printer - dot-matrix - 9 pin - B/W
- 7.2 kg
- Localisation
- United Kingdom
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Print Speed
- Up to 680 char/sec - max speed , Up to 566 char/sec - max speed , Up to 627 char/sec - fast draft , Up to 559 char/sec - fast draft , Up to 503 char/sec - draft , Up to 419 char/sec - draft , Up to 125.9 char/sec - letter , Up to 104.6 char/sec - letter
- Interface
- Parallel, USB
- RAM Installed (Max)
- 128 KB
- Barcodes
- Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
- System Requirements
- Microsoft Windows 95/98, Microsoft Windows 2000 / NT4.0, Microsoft Windows Millennium Edition, Microsoft Windows XP
- Microsoft Certification
- Works with Windows Vista
- 1-year warranty
- 41.4 cm x 35 cm x 16.8 cm
- Printer Type
- Workgroup printer - dot-matrix - 9 pin - monochrome
- Localisation
- United Kingdom
Printer
- Print Speed
- Up to 680 char/sec - max speed - 12 cpi , Up to 566 char/sec - max speed - 10 cpi , Up to 627 char/sec - fast draft - 12 cpi , Up to 559 char/sec - fast draft - 10 cpi , Up to 503 char/sec - draft - 12 cpi , Up to 419 char/sec - draft - 10 cpi , Up to 125.9 char/sec - letter - 12 cpi , Up to 104.6 char/sec - letter - 10 cpi
- Connectivity Technology
- Wired
- Interface
- Parallel, USB
- Fonts Included
- 3 x bitmapped , 8 x barcode
- Barcodes
RAM
- 128 KB
Media Handling
- Media Size Class
- A4
- Max Media Size
- A4 (210 x 297 mm)
- Media Sizes
- A4 (210 x 297 mm)
- Max Sheets in Multi-Part Form
- 6
- Connections
- 1 x USB , 1 x parallel
- Consumables Included
- 1 x ribbon (black) - up to 7.5 million characters
- MTBF
- 20,000 hour(s)
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Software Included
- EPSON Status Monitor 3
- OS Required
- Limited warranty - 1 year
- Sound Emission (Operating)
- 55 dBA
- 41.4 cm
- 35 cm
- 16.8 cm
- 7.2 kg
Epson FC-890 Ribbon Cartridge | In Stock | £4.83 |
