This wide carriage printer combines high speed printing with outstanding reliability.
A mean volume between failure of 52 million lines makes this printer suitable for medium and large print volumes. The paper can be fed from the front, top, rear or bottom and an optional additional push/pull tractor unit can store a second continuous form, which is ideal for commercial and industrial environments.
- Epson FX 2190N - printer - B/W - dot-matrix
- Printer Type
- Workgroup printer - dot-matrix - 9 pin - B/W
- 9.4 kg
- Max Media Size
- 364 x 420 mm, continuous paper 102 mm - 406 mm (width)
- Max Media Size (Custom)
- 420 mm x 364 mm
- Print Speed
- Up to 680 char/sec - max speed , Up to 566 char/sec - max speed , Up to 559 char/sec - fast draft , Up to 627 char/sec - fast draft , Up to 419 char/sec - draft , Up to 503 char/sec - draft , Up to 104.6 char/sec - near letter , Up to 125.9 char/sec - near letter
- Interface
- Parallel, USB, LAN
- RAM Installed (Max)
- 128 KB
- Language Simulation
- EPSON ESC/P, IBM PPDS
- Barcodes
- Code 39, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Code 128, Interleaved 2 of 5, Postnet
- Media Type
- Envelopes, labels, plain paper, continuous forms
- Monthly Duty Cycle (max)
- 23000 pages
- Networking
- Print server - Ethernet, Fast Ethernet - plug-in module
- Microsoft Certification
- Works with Windows Vista
- 1-year warranty
- 58.9 cm x 35 cm x 16.8 cm
- Printer Type
- Workgroup printer - dot-matrix - 9 pin - monochrome
Printer
- Print Speed
- Up to 680 char/sec - max speed - 12 cpi , Up to 566 char/sec - max speed - 10 cpi , Up to 559 char/sec - fast draft - 10 cpi , Up to 627 char/sec - fast draft - 12 cpi , Up to 419 char/sec - draft - 10 cpi , Up to 503 char/sec - draft - 12 cpi , Up to 104.6 char/sec - near letter - 10 cpi , Up to 125.9 char/sec - near letter - 12 cpi
- Connectivity Technology
- Wired
- Interface
- Barcodes
RAM
- 128 KB
Media Handling
- Media Type
- Max Media Size
- 420 mm x 364 mm
- Media Sizes
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), US No 6 (92 x 165 mm)
- Max Sheets in Multi-Part Form
- 6
Duty Cycle
- 23000 pages
- Networking
- Print server - plug-in module
- Data Link Protocol
- Connections
- 1 x parallel , 1 x USB - 4 pin USB Type B , 1 x LAN - RJ-45
- MTBF
- 20,000 hour(s)
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 53 Watt
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year
- Sound Emission (Operating)
- 55 dBA
- 58.9 cm
- 35 cm
- 16.8 cm
- 9.4 kg
Epson Black Fabric Ribbon for FX2190 | In Stock | £10.24 |
