Epson Expression Premium XP-630 Colour Inkjet Multifunction Printer
Quicklinx: BMFWWS00 Mfr#: C11CE79401
Best of both worlds
Create outstanding glossy photos and crisp, clear text documents with the new five-colour Claria Premium dye and pigment ink-set. Photographs will be crystal clear with vibrant colours and deep, rich blacks thanks to the addition of a Photo Black ink cartridge. The use of individual ink cartridges means only the colour used need to be replaced to help save on ink costs.
Mobile printing
Whether using a smartphone or tablet, the iPrint app can be downloaded to a range of devices for truly wireless printing and scanning. The possibilities don't end there, with Epson Email Print , it is possible to print from anywhere in the world by simply emailing documents and photos directly to the printer. For creative-minded people the Creative Print app can access Facebook photos, create custom greeting cards and stationery, and even turn photos into colouring book templates. For added versatility, Wi-Fi Direct allows easy printing from compatible wireless devices without the need for a network connection.
Easy to use features
For maximum control, the XP-630 comes with a tilting control panel and 6.8cm LCD screen with touchpad for easy navigation. Dual paper trays, one for A4 and one for photo paper, and fast, double-sided printing helps save time. Users can also simply slot in a memory card and follow the helpful menu prompts to print photos without a PC.
  • Wi-Fi all-in-one with duplex
    Produce outstanding photos and crisp, clear text with this Wi-Fi all-in-one with individual inks and a range of easy-to-use features.
  • Introducing the Expression Premium XP-630
    Ideally suited for printing outstanding photos and text documents at home, the XP-630 is the ultimate tool for those users wanting the best of both worlds. Featuring individual inks, mobile printing and a range of easy-to-use features, producing high-quality documents and photos has never been easier or more cost effective.Not just for printing, the XP-630 can also copy and scan high-quality documents and photos. It's what's on the inside that makes the XP-630 really stand out. From the inks to the printhead, each element is designed by us and created to work in harmony. The results are great looking, long-lasting prints that users will be proud to display and share.We understand that producing high-quality photos and documents shouldn't just be possible from a computer. With a range of mobile printing options, the XP-630 makes it quick and simple to print stunning photos from smartphones and tablets . Users can print straight from a memory card by simply following the helpful menu prompts on the LCD screen.The XP-630 also has all the familiar features that have made the Expression Premium range such a success. Fitted with two paper trays, switching between different media is quick and easy, while fast, double-sided printing helps save time and reduce paper usage.
  • Outstanding results
    Create outstanding glossy photos and crisp, clear text documents with the new five-colour Claria Premium dye and pigment ink-set. Photographs will be crystal clear with vibrant colours and deep, rich blacks thanks to the addition of a Photo Black ink cartridge. It's fast too so you can print your favourite photos without worrying about compromising on quality.
  • Easy mobile printing
    Whether using a smartphone or tablet, the iPrint app can be downloaded to a range of devices for truly wireless printing and scanning. The possibilities don't end there, with Epson Email Print , it is possible to print from almost anywhere in the world by simply emailing documents and photos directly to the printer. For creative-minded people the Creative Print app can print photos directly from Facebook, create custom greeting cards and stationery, and even turn photos into colouring book templates. For added versatility, Wi-Fi Direct allows easy printing from compatible wireless devices without the need for a network connection. It's also compatible with Apple AirPrint letting you print from an iPad, iPhone or iPod Touch .
  • Flexible and easy to use
    A tilting control panel and 6.8cm LCD screen makes navigation of the menu easy. Featuring dual paper trays, users can use one tray for A4 paper and the other for photo paper and easily switch between the two. Printing on suitable CDs and DVDs to create personalised covers is also possible.
  • Same time and money
    Using individual ink cartridges means only the colour used need to be replaced to help users save on ink costs. No-one wants to use more paper than they have to, and with duplex printing, the XP-630 instantly cuts paper usage in half. This also has the added bonus of saving money too.
  • Who needs cables?
    No one wants to spend time with cables and manuals setting-up a printer, which is why the user-friendly XP-630 comes with auto Wi-Fi setup , which configures the settings quickly and securely. With Wi-Fi Direct also included, it's easy to print photos or documents stored on smartphones or tablets , even without a home network. Able to quickly make a direct link to your mobile device, the XP-630 can print off documents and photos almost immediately, without the need for cables. Users can even simply slot in a memory card and follow the helpful menu prompts on the LCD screen to print photos without a PC.
  • Good looking and compact
    Stylish and compact - the XP-630's small and lightweight design means it doesn't take up much valuable desk space and is sure to complement any home.
Epson Expression Premium XP-630 - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 13 ppm (mono) / up to 10 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Scanning
1200 x 2400 dpi
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB, USB host, Wi-Fi
AirPrint Enabled
Office Machine Features
Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive
AC 230 V
39 cm x 34.1 cm x 13.8 cm
6.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
Display Features
Touch screen
AirPrint Enabled
Supported Flash Memory
SD Memory Card, USB flash drive, SDHC Memory Card, SDXC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
360 nozzles (black), 180 nozzles (per colour)
Max Printing Speed
Ink Cartridge Configuration
5 cartridges (1 each: cyan, magenta, yellow, black, photo balck)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, photo black
4-ink
Minimum Ink Droplet Size
1.5 pl
Ink Type
Epson Claria Premium Ink
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Document & Media Handling
Original Type
Sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
100 sheets
Input tray - 100 sheets , CD/DVD tray
Speed Details
Printing: up to 32 ppm - B/W , Printing: up to 32 ppm - colour , Printing: up to 13 ppm - B/W (ISO/IEC 24734) , Printing: up to 10 ppm - colour (ISO/IEC 24734) , Printing: 20 sec (10 x 15 cm (4"x6")) - photo
1 x USB , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
WEP, WPA-PSK, Wi-Fi Direct
Operating System Support
MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, MS Windows XP (32/64 bits)
Software Included
Drivers & Utilities, EPSON Print CD, Epson Easy Photo Print
AC 230 V
18 Watt
Power Consumption Standby
1.2 Watt
Consumables Included
1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (photo black)
ENERGY STAR Certified
39 cm
34.1 cm
13.8 cm
6.7 kg
Sound Emission
37 dBA (operating)
BMFW Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £14.96
BMFW Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.37
BMFW Epson A4 Iron On Transfer Pack 10sht In Stock £13.23
BMFW Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.37
BMFW Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £14.69
