Best of both worlds
Create outstanding glossy photos and crisp, clear text documents with the new five-colour Claria Premium dye and pigment ink-set. Photographs will be crystal clear with vibrant colours and deep, rich blacks thanks to the addition of a Photo Black ink cartridge. The use of individual ink cartridges means only the colour used need to be replaced to help save on ink costs.
Mobile printing
Whether using a smartphone or tablet, the iPrint app can be downloaded to a range of devices for truly wireless printing and scanning. The possibilities don't end there, with Epson Email Print , it is possible to print from anywhere in the world by simply emailing documents and photos directly to the printer. For creative-minded people the Creative Print app can access Facebook photos, create custom greeting cards and stationery, and even turn photos into colouring book templates. For added versatility, Wi-Fi Direct allows easy printing from compatible wireless devices without the need for a network connection.
Easy to use features
For maximum control, the XP-630 comes with a tilting control panel and 6.8cm LCD screen with touchpad for easy navigation. Dual paper trays, one for A4 and one for photo paper, and fast, double-sided printing helps save time. Users can also simply slot in a memory card and follow the helpful menu prompts to print photos without a PC.
Wi-Fi all-in-one with duplex
Produce outstanding photos and crisp, clear text with this Wi-Fi all-in-one with individual inks and a range of easy-to-use features. -
Introducing the Expression Premium XP-630
Ideally suited for printing outstanding photos and text documents at home, the XP-630 is the ultimate tool for those users wanting the best of both worlds. Featuring individual inks, mobile printing and a range of easy-to-use features, producing high-quality documents and photos has never been easier or more cost effective.Not just for printing, the XP-630 can also copy and scan high-quality documents and photos. It's what's on the inside that makes the XP-630 really stand out. From the inks to the printhead, each element is designed by us and created to work in harmony. The results are great looking, long-lasting prints that users will be proud to display and share.We understand that producing high-quality photos and documents shouldn't just be possible from a computer. With a range of mobile printing options, the XP-630 makes it quick and simple to print stunning photos from smartphones and tablets . Users can print straight from a memory card by simply following the helpful menu prompts on the LCD screen.The XP-630 also has all the familiar features that have made the Expression Premium range such a success. Fitted with two paper trays, switching between different media is quick and easy, while fast, double-sided printing helps save time and reduce paper usage. -
Outstanding results
Create outstanding glossy photos and crisp, clear text documents with the new five-colour Claria Premium dye and pigment ink-set. Photographs will be crystal clear with vibrant colours and deep, rich blacks thanks to the addition of a Photo Black ink cartridge. It's fast too so you can print your favourite photos without worrying about compromising on quality. -
Easy mobile printing
Whether using a smartphone or tablet, the iPrint app can be downloaded to a range of devices for truly wireless printing and scanning. The possibilities don't end there, with Epson Email Print , it is possible to print from almost anywhere in the world by simply emailing documents and photos directly to the printer. For creative-minded people the Creative Print app can print photos directly from Facebook, create custom greeting cards and stationery, and even turn photos into colouring book templates. For added versatility, Wi-Fi Direct allows easy printing from compatible wireless devices without the need for a network connection. It's also compatible with Apple AirPrint letting you print from an iPad, iPhone or iPod Touch . -
Flexible and easy to use
A tilting control panel and 6.8cm LCD screen makes navigation of the menu easy. Featuring dual paper trays, users can use one tray for A4 paper and the other for photo paper and easily switch between the two. Printing on suitable CDs and DVDs to create personalised covers is also possible. -
Same time and money
Using individual ink cartridges means only the colour used need to be replaced to help users save on ink costs. No-one wants to use more paper than they have to, and with duplex printing, the XP-630 instantly cuts paper usage in half. This also has the added bonus of saving money too. -
Who needs cables?
No one wants to spend time with cables and manuals setting-up a printer, which is why the user-friendly XP-630 comes with auto Wi-Fi setup , which configures the settings quickly and securely. With Wi-Fi Direct also included, it's easy to print photos or documents stored on smartphones or tablets , even without a home network. Able to quickly make a direct link to your mobile device, the XP-630 can print off documents and photos almost immediately, without the need for cables. Users can even simply slot in a memory card and follow the helpful menu prompts on the LCD screen to print photos without a PC. -
Good looking and compact
Stylish and compact - the XP-630's small and lightweight design means it doesn't take up much valuable desk space and is sure to complement any home.
- Epson Expression Premium XP-630 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson Micro Piezo - 4-ink
- Max Printing Speed
- Up to 13 ppm (mono) / up to 10 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB, USB host, Wi-Fi
- AirPrint Enabled
- Office Machine Features
- Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive
- Power
- AC 230 V
- 39 cm x 34.1 cm x 13.8 cm
- 6.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Ink-jet - colour
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Supported Flash Memory
- SD Memory Card, USB flash drive, SDHC Memory Card, SDXC Memory Card
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 360 nozzles (black), 180 nozzles (per colour)
- Ink Cartridge Configuration
- 5 cartridges (1 each: cyan, magenta, yellow, black, photo balck)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black, photo black
- 4-ink
- Minimum Ink Droplet Size
- 1.5 pl
- Ink Type
- Epson Claria Premium Ink
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Document & Media Handling
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 100 sheets
- Input tray - 100 sheets , CD/DVD tray
- Speed Details
- Printing: up to 32 ppm - B/W , Printing: up to 32 ppm - colour , Printing: up to 13 ppm - B/W (ISO/IEC 24734) , Printing: up to 10 ppm - colour (ISO/IEC 24734) , Printing: 20 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB , 1 x USB host - 4 pin USB Type A
- WEP, WPA-PSK, Wi-Fi Direct
- Operating System Support
- MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, MS Windows XP (32/64 bits)
- Software Included
- Drivers & Utilities, EPSON Print CD, Epson Easy Photo Print
- Voltage Required
- AC 230 V
- 18 Watt
- Power Consumption Standby
- 1.2 Watt
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (photo black)
- ENERGY STAR Certified
- 39 cm
- 34.1 cm
- 13.8 cm
- 6.7 kg
- Sound Emission
- 37 dBA (operating)
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £14.99 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.37 |
Epson A4 Iron On Transfer Pack 10sht | In Stock | £13.27 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.37 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £13.79 |
