Compact yet feature rich
Surprisingly compact, the XP-15000 can print A3+ photos from its small footprint. It's stylish too and looks great from all angles.
Enhanced inks
Print long-lasting and professional-looking glossy photos with Claria Photo HD Inks. The set of six inks includes grey for superior black and white photos with a smoother tonal gradation, and red for vivid and realistic colours thanks to the wider colour gamut.
Print when and where you want
Printing photos and documents on the go is easy; simply download the free Epson iPrint app to print wirelessly from your smart device. The free Epson Creative Print app can print photos directly from Facebook, create greeting cards, turn photos into colouring books, and plenty more. You can even print by emailing files to the printer from almost anywhere in the world with Epson Email Print .
Flexible
Print wirelessly with or without a network using Wi-Fi and Wi-Fi Direct. There is also Ethernet for printing through a wired network. In addition, the auto power on feature activates the printer and automatically opens the output tray when a print job is sent.
Versatile
The front-loading paper tray can be used for paper up to A4, while the rear paper feed is suitable for up to A3+ including thicker media. You can also print A4 double-sided and on suitable CDs and DVDs.
Compact A3+ photo printer
Produce professional-looking, glossy photos from Epson's smallest A3+ photo printer. Enjoy natural and vibrant prints with greater detail thanks to the six colour Claria Photo HD Inks with red and grey. -
Welcome to the Expression Photo HD XP-15000
Sophisticated equipment doesn't need to take up lots of space; this wireless photo printer produces superior, A3+ photos from a surprisingly compact and small footprint making it Epson's smallest A3+ photo printer. It's stylish too, with sleek clean lines that make it look great from every angle.For prints that you can be proud of, this dedicated photo printer delivers professional looking and long-lasting photographs at your convenience. Both photography enthusiasts and semi-professionals are sure to appreciate the enhanced level of quality offered by the six-colour Claria Photo HD ink set which includes red and grey.Here's a photo printer that will make a whole range of creative tasks easy to accomplish at home. You can print up to A3+ on a range of media including thicker papers, card, CDs and DVDs. It's also quick and easy to use with fast print speeds and A4 auto double-sided printing. It packs in lots of user-friendly features including a 6.1cm LCD screen, auto open output tray and auto power on.There's no need to be held back by computers or wires; use Wi-Fi, Wi-Fi Direct and our suite of free mobile printings apps to print on the go. You can be free from constraints and send your items to print from a smartphone or tablet - at home or from almost anywhere in the world . -
Stylish and space-saving
Integrating technology into the home can be a challenge, so if you're squeezed for space, the compact and space-saving design of the XP-15000 can provide a great solution. While it may have a small footprint, the XP-15000 actually offers A3+ photo printing. It's stylish too with sleek, clean lines on every side. -
Enhanced inks
Print long-lasting and professional-looking, glossy photos at your convenience with Claria Photo HD Inks, which includes grey and red in addition to cyan, yellow, magenta and black. With the grey ink, superior black and white photos can be achieved with smoother gradations between the shadows and highlights. With the red ink, an extra-wide colour gamut is possible resulting in more realistic and vibrant colours. And rest assured; treasured memories will be kept safe as the high-quality Claria Photo HD Ink can last for 300 years in a photo album . -
Enable your complete artistic vision
With the XP-15000, it's easy to handle a range of creative tasks from the convenience of your home. The front-loading paper tray is designed for printing up to A4 photos or documents with the flexibility to print double-sided. Alternatively, the rear media feed can be utilised for specialist thicker card or printing up to A3+. Additionally, you can print on suitable CDs and DVDs. -
Automated and user-friendly
There's no need to walk back and forth to manually switch the printer on - the auto power on feature does this automatically. It turns the printer on and opens the motorised output tray when a print job is sent, saving unnecessary trips to the printer. Just remember to fill the paper trays and check ink levels. -
Easy mobile printing
Wireless printing with or without a network is possible thanks to Wi-Fi and Wi-Fi Direct. It means you can print photos and documents on the go with this photo printer. To unlock the potential of your smartphone or tablet, simply download the free Epson iPrint app to print wirelessly. Make the most of your Facebook photos with the free Epson Creative Print app, which allows you to print photos directly from Facebook, create custom greeting cards, turn photos into colouring book templates, and plenty more. In addition, you can email documents and photos directly to the printer from almost anywhere in the world with Epson Email Print .
- Epson Expression Photo HD XP-15000 - printer - colour - ink-jet
- Printer Type
- Workgroup printer - ink-jet - colour
- 8.5 kg
- Inkjet Technology
- Epson Micro Piezo
- Ink Palette Supported (Colours)
- 6-ink - cyan, magenta, yellow, black, red, grey
- Media Size Class
- A3
- Max Media Size
- A3 Plus (330.2 x 482.6 mm)
- Print Speed
- Up to 9.2 ppm - B/W (ISO/IEC 24734) , Up to 9 ppm - color (ISO/IEC 24734) , Up to 29 ppm - B/W , Up to 29 ppm - colour
- Max Resolution (B&W)
- 5760 x 1400 dpi
- Max Resolution (Colour)
- 5760 x 1400 dpi
- Max Resolution Class (B&W)
- 5760 x 1400 dpi
- Max Resolution Class (Colour)
- 5760 x 1400 dpi
- Automatic Duplexing
- Print on CD/DVD
- Interface
- USB, LAN, Wi-Fi(n)
- Media Type
- Envelopes, plain paper, photo paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 200-sheet input tray, 50-sheet photo paper tray
- Networking
- Print server
- Printer Features
- Red eye reduction
- System Requirements
- Microsoft Windows 7, Microsoft Windows XP SP3, Microsoft Windows XP Professional 64-bit Edition SP2, Apple MacOS X 10.6.8 or later, Windows 8, Windows 8.1, Windows 10
- 1-year warranty
- 47.6 cm x 37 cm x 15.9 cm
- Printer Type
Printer
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 180 nozzles (per cartridge)
- Minimum Ink Droplet Size
- 1.5 pl
- Ink Cartridge Configuration
- 6 individual ink tanks
- Ink Type
- Epson Claria Photo HD Ink
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 5760 x 1400 dpi
- 5760 x 1400 dpi
- 5760 x 1400 dpi
- 5760 x 1400 dpi
- Print on CD/DVD
- Direct Printing Specifications
- PictBridge
- Printer Features
- Red eye reduction
- Media Handling
Media Handling
- Media Type
- Media Size Class
- A3
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm, A3 Plus (330.2 x 482.6 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 250 sheets
- Media Feeders
- Input tray: 1 x automatic - 200 sheets , Photo tray: 1 x automatic - 50 sheets
- Max Media Capacity
- 250 sheets
- Networking
- Print server
- WEP, WPA-PSK, Wi-Fi Direct
- Connections
- 1 x USB , 1 x LAN - RJ-45
- Consumables Included
- 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow) , 1 x ink cartridge (black) , 1 x ink cartridge (red) , 1 x ink cartridge (grey)
- Power Device
- Power supply - internal
- 21 Watt
- Power Consumption Stand by
- 5.7 Watt
- Power Consumption Sleep
- 0.8 Watt
- Software Included
- EPSON Print CD, EPSON Easy Photo Print
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - carry-in
- Sound Emission (Operating)
- 36 dBA
- 47.6 cm
- 37 cm
- 15.9 cm
- 8.5 kg
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £9.02 |
Epson A4 Iron On Transfer Pack 10sht | In Stock | £11.94 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £11.83 |
