Epson Expression Home XP-452 Colour Ink-Jet Multifunction Printer
Quicklinx: DWGTWS00 Mfr#: C11CH15401
Type: Printer / copier / scanner
Functionality: Copier, Printer, Scanner
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
13 in stock
£63.37 ex VAT
£76.04 inc VAT
Stylish small-in-one
Don't let a printer impact your decor - our stylish and compact small-in-one range is designed to integrate into the home. This affordable model efficiently uses your space combining printing, scanning and copying facilities in one unit.
Easy to use
This printer is designed to be effortless to use with all the essentials and a range of extras for your convenience. It's versatile with Wi-Fi for printing and scanning wirelessly around the home, and Wi-Fi Direct for printing without a wireless network. Share scans with Scan-to-cloud, and print photos without a computer using its memory card slot and 6.8cm LCD screen.
Efficient & affordable
Utilising Epson's Claria Home Inks, this small-in-one is ideal for producing crisp, clear text documents and glossy, high-quality photos. Get more for your money too with individual inks, as only the colour used needs to be replaced.
Unleash smart devices
Enjoy wireless printing and scanning around the home via Epson's free iPrint app . Alternatively, Email Print makes it possible to print from almost anywhere in the world by simply emailing files to the printer . Feeling artistic? The Creative Print app can print photos directly from Facebook, create custom greeting cards and stationery, and even turn photos into colouring book templates .You can also take advantage of Apple Airprint .
  • Small-in-one with large screen
    Save money, space and time with this small-in-one with Wi-Fi Direct, featuring individual inks, mobile printing and memory card slot.
Epson Expression Home XP-452 - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 33 ppm (mono) / up to 15 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Max Printing Resolution Class
Scanning
1200 x 2400 dpi
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
Connection Availability
USB, Wi-Fi
AirPrint Enabled
Office Machine Features
Print from memory card, scan to Cloud
AC 230 V
39 cm x 30 cm x 14.6 cm
4.3 kg
Enclosure Colour
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
Colour Support
Display Features
Touch screen
USB, Wi-Fi
AirPrint Enabled
Enclosure Colour
Supported Flash Memory
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
180 nozzles (black), 3 x 59 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3 pl
Ink Type
Epson Claria Home Ink
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Document & Media Handling
Supported Original Sizes
A4 (210 x 297 mm)
Original Type
Sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
100 sheets
Input tray - 100 sheets
Speed Details
Printing: up to 10 ppm - B/W (ISO/IEC 24734) , Printing: up to 4.5 ppm - color (ISO/IEC 24734) , Printing: up to 33 ppm - B/W , Printing: up to 15 ppm - colour , Printing: 38 sec (10 x 15 cm (4"x6")) - photo
1 x USB
Security Protocols & Features
WEP, WPA-PSK, Wi-Fi Direct
Operating System Support
MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, Windows 8.1, Windows 10
Software Included
Epson Easy Photo Print
AC 230 V
13 Watt
Power Consumption Sleep
1.6 Watt
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
ENERGY STAR Certified
39 cm
30 cm
14.6 cm
4.3 kg
Sound Emission
37 dBA (operating)
DWGT Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £13.51
DWGT Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £9.83
DWGT Epson Matte Paper Heavyweight A4 50 sheets In Stock £9.83
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Technology: Ink-jet
Max Print Speed: 33ppm
Max Paper Size: A4 (210 x 297 mm)
Brand: Epson
Price Range Ex VAT: 50 - 100
