Efficient & affordable
Utilising Epson's Claria Home Inks, this small-in-one is ideal for producing crisp, clear text and glossy, lab-quality photos. Individual ink cartridges mean only the colour used needs to be replaced to save on costs.
Mobile printing
Whether using a smartphone or tablet, the iPrint app can be downloaded to a range of devices for truly wireless printing and scanning. The possibilities don't end there, with Epson Email Print , it is possible to print from anywhere in the world by simply emailing documents and photos directly to the printer. For creative-minded people, the Creative Print app can access Facebook photos, create custom greeting cards and stationery, and even turn photos into colouring book templates. For added versatility, Wi-Fi Direct allows easy printing from compatible wireless devices without the need for a network connection.
PC-free printing
Simply slot in a memory card and use the 6.8cm colour LCD screen and helpful menu prompts to print your photos without a PC.
Space saving
Stylish and compact - the XP-432's small and lightweight design means it doesn't take up much valuable desk space.
Utilising Epson's Claria Home Inks, this small-in-one is ideal for producing crisp, clear text and glossy, lab-quality photos. Individual ink cartridges mean only the colour used needs to be replaced to save on costs. -
Mobile printing
Whether using a smartphone or tablet, the iPrint app can be downloaded to a range of devices for truly wireless printing and scanning. The possibilities don't end there, with Epson Email Print, it is possible to print from anywhere in the world by simply emailing documents and photos directly to the printer. For creative-minded people, the Creative Print app can access Facebook photos, create custom greeting cards and stationery, and even turn photos into colouring book templates. For added versatility, Wi-Fi Direct allows easy printing from compatible wireless devices without the need for a network connection. -
PC-free printing
Simply slot in a memory card and use the 6.8cm colour LCD screen and helpful menu prompts to print your photos without a PC. -
Space saving
- Epson Expression Home XP-432 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson Micro Piezo - 4-ink
- Max Printing Speed
- Up to 9 ppm (mono) / up to 4.5 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 100 sheets
- Connection Availability
- Interface
- USB, Wi-Fi
- AirPrint Enabled
- Office Machine Features
- Print from memory card, save to memory card
- Power
- AC 230 V
- 39 cm x 30 cm x 14.5 cm
- 4.2 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- Ink-jet - colour
- Display Features
- Touch screen
- Interface
- USB, Wi-Fi
- AirPrint Enabled
- Supported Flash Memory
- SD Memory Card, SDHC Memory Card, SDXC Memory Card
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 180 nozzles (black), 3 x 59 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 3 pl
- Ink Type
- Epson Claria Home Ink
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Document & Media Handling
- Original Type
- Sheets
- Max Media Size
- A4/Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 100 sheets
- Input tray - 100 sheets
- Speed Details
- Printing: up to 9 ppm - B/W (ISO/IEC 24734) , Printing: up to 4.5 ppm - colour (ISO/IEC 24734) , Printing: up to 33 ppm - B/W , Printing: up to 15 ppm - colour , Printing: 38 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB
- WEP, WPA-PSK, Wi-Fi Direct
- Operating System Support
- MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, MS Windows XP (32/64 bits)
- Software Included
- Epson Easy Photo Print
- Voltage Required
- AC 230 V
- 13 Watt
- Power Consumption Standby
- 1.6 Watt
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- ENERGY STAR Certified
- 39 cm
- 30 cm
- 14.5 cm
- 4.2 kg
- Sound Emission
- 37 dBA (operating)
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £14.99 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £11.37 |
Epson A4 Iron On Transfer Pack 10sht | In Stock | £13.27 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £11.37 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £14.69 |
Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) | In Stock | £14.69 |
