Your basket is empty
Epson Expression Home XP-432 Colour Inkjet Multifunction Printer
Quicklinx: BMFVWS00 Mfr#: C11CE62401
Efficient & affordable
Utilising Epson's Claria Home Inks, this small-in-one is ideal for producing crisp, clear text and glossy, lab-quality photos. Individual ink cartridges mean only the colour used needs to be replaced to save on costs.
Mobile printing
Whether using a smartphone or tablet, the iPrint app can be downloaded to a range of devices for truly wireless printing and scanning. The possibilities don't end there, with Epson Email Print , it is possible to print from anywhere in the world by simply emailing documents and photos directly to the printer. For creative-minded people, the Creative Print app can access Facebook photos, create custom greeting cards and stationery, and even turn photos into colouring book templates. For added versatility, Wi-Fi Direct allows easy printing from compatible wireless devices without the need for a network connection.
PC-free printing
Simply slot in a memory card and use the 6.8cm colour LCD screen and helpful menu prompts to print your photos without a PC.
Space saving
Stylish and compact - the XP-432's small and lightweight design means it doesn't take up much valuable desk space.
Epson Expression Home XP-432 - multifunction printer (colour)
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 4-ink
Max Printing Speed
Up to 33 ppm (mono) / up to 15 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Scanning
1200 x 2400 dpi
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
Connection Availability
USB, Wi-Fi
AirPrint Enabled
Office Machine Features
Print from memory card, save to memory card
AC 230 V
39 cm x 30 cm x 14.5 cm
4.2 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Printing Technology
Ink-jet - colour
Display Features
Touch screen
USB, Wi-Fi
AirPrint Enabled
Supported Flash Memory
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
180 nozzles (black), 3 x 59 nozzles (cyan, magenta, yellow)
Max Printing Speed
Ink Cartridge Configuration
4 cartridges (1 each: cyan, magenta, yellow, black)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Minimum Ink Droplet Size
3 pl
Ink Type
Epson Claria Home Ink
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Document & Media Handling
Original Type
Sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
100 sheets
Input tray - 100 sheets
Speed Details
Printing: up to 9 ppm - B/W (ISO/IEC 24734) , Printing: up to 4.5 ppm - color (ISO/IEC 24734) , Printing: up to 33 ppm - B/W , Printing: up to 15 ppm - colour , Printing: 38 sec (10 x 15 cm (4"x6")) - photo
1 x USB
Security Protocols & Features
WEP, WPA-PSK, Wi-Fi Direct
Operating System Support
MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, MS Windows XP (32/64 bits)
Software Included
Epson Easy Photo Print
AC 230 V
13 Watt
Power Consumption Standby
1.6 Watt
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow)
ENERGY STAR Certified
39 cm
30 cm
14.5 cm
4.2 kg
Sound Emission
37 dBA (operating)
BMFV Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £12.79
BMFV Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £9.20
BMFV Epson A4 Photo Self - Adhesive 10sht In Stock £8.79
BMFV Epson Matte Paper Heavyweight A4 50 sheets In Stock £8.98
BMFV Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £11.61
BMFV Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) In Stock £11.61
