Epson Expression 12000XL Pro Flatbed Scanner
Quicklinx: CTMRWS00 Mfr#: B11B240401BU
Hurry, only 3 left in stock!
£3,463.46 ex VAT
£4,156.15 inc VAT
Sharp and accurate image reproduction
Thanks to the Expression 12000XL Pro's top-of-the-range scanning technology, users can achieve extremely high-quality image reproduction up to A3 format. Easy-to-use, Epson Scan operates in either automatic or professional modes, allowing users to optimise their scanning results.
The Expression 12000XL Pro's optical density of 3.8 DMax and 48-bit colour depth ensure sharp and accurate scanning for full reproduction of the widest range of colours, even in shadow areas. In addition, the high 2400 x 4800dpi resolution and ultra-precise Micro Step Drive technology, enable users to capture even the tiniest details with exceptional clarity.
Sharpen and edit your scans
A comprehensive package of bundled software and imaging technology ensures the Expression 12000XL Pro can perform a wide range of functions easily and efficiently. Epson Scan comes with useful features for removing dust noise and grain reduction to smooth the appearance of images. SilverFast Ai 8.8's image-processing functions help get even closer to perfect image reproduction.
Scan a range of media, including film negatives
The included transparency unit enables users to scan from transparency media, such as positive or negative film and slides, with professional results.
  • A3 film and graphics scanner
    High-quality A3 film and graphics scanner for sharp and accurate capturing of plans, x-rays, film negatives, with the precision users demand.
Epson Expression 12000XL Pro - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Light Source
LED
Max Supported Document Size
DIN A3 (310 x 437 mm)
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 16-bit (64k colours)
Grayscale / Color Depth (External)
48-bit colour / 48-bit colour
Optical Resolution
2400 dpi x 4800 dpi
Max Document Size
310 mm x 437 mm
Document Feeder Type
Manual
Microsoft Windows XP, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7.x, Apple MacOS X 10.6.8, Windows 8 (32/64 bits), Apple MacOS X 10.8.x, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Windows 10, Apple MacOS X 10.10.x, Microsoft Windows Server 2012 (64-bit), Apple MacOS X 10.11
65.5 cm x 46 cm x 29.2 cm
20.5 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
48-bit colour
Colour Depth
Colour Depth (External)
48-bit colour
Optical Resolution
2400 dpi x 4800 dpi
Bulb / Light Source Type
LED
Scan Density Range
3.8D
Scanner Speed Details
7 sec/scan - greyscale - A4 - 300 dpi , 7 sec/scan - colour - A4 - 300 dpi
Scanner Features
EPSON ReadyScan LED Technology
Media Handling
Max Document Size
310 mm x 437 mm
Manual
USB 2.0 - Type B
A3 transparency unit
1 x USB cable
ENERGY STAR Certified
Software Included
EPSON Scan 2, SilverFast Ai Studio 8.8
65.5 cm
46 cm
29.2 cm
20.5 kg
5 °C
35 °C
10 - 80%
Brand: Epson
Price Range Ex VAT: 1500+
