Thanks to the Expression 11000XL Pro's top-of-the-range scanning technology, users can achieve extremely high-quality image reproduction up to A3 format. Easy-to-use, Epson Scan operates in automatic or professional modes, allowing users to optimize their scanning results.
The scanner's optical density of 3.8 DMax and 48-bit colour depth ensure sharp and accurate scanning for full reproduction of the widest range of colours, even in shadow areas. In addition, the high 2400 x 4800dpi resolution and ultra-precise Micro Step Drive technology, enable users to capture even the tiniest details with exceptional clarity.
A comprehensive package of bundled software and imaging technology enables the Expression 11000XL Pro to perform a wide range of functions easily and efficiently. Epson Scan comes with useful features for removing dust noise and grain reduction to smooth the appearance of images. SilverFast Ai8 is included for advanced users, with an intuitive user-friendly interface and processing functions to help get even closer to perfect image reproduction.
The included transparency unit enables users to scan from transparency media, such as positive or negative film and slides, with professional results.
A3 graphic scanner
High-resolution A3 scanner with transparency unit for sharp, accurate scans that meet the standards of the graphic arts industry.
- Epson Expression 11000XL Pro - flatbed scanner - desktop - USB 2.0
- Flatbed scanner - desktop
- Interface Type
- USB 2.0
- Light Source
- Xenon gas fluorescent lamp
- Max Supported Document Size
- DIN A3 (310 x 437 mm)
- Input Type
- Grayscale / Color Depth
- 16-bit (64K grey levels) / 48-bit colour
- Optical Resolution
- 2400 dpi x 4800 dpi
- Max Document Size
- 310 mm x 437 mm
- Supported Document Type
- Plain paper
- Document Feeder Type
- Manual
- System Requirements
- Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.5.8, Windows 8
- 65.6 cm x 45.8 cm x 29.2 cm
- 19.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 48-bit colour
- Scan Mode
- Single-pass
- Bulb / Light Source Type
- Scan Density Range
- 3.8D
- Scanner Speed Details
- 7 sec/scan - greyscale - 200 dpi , 7 sec/scan - colour - 200 dpi , 2.7 ms/line - greyscale , 8 ms/line - colour
Media Handling
- Max Document Size
- 310 mm x 437 mm
- Plain paper
- Manual
- USB 2.0 - Type B
- Included Accessories
- Transparency adaptor, IT8 transparent calibration target
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Power Consumption Operational (Standby)
- 50 Watt
- Software Included
- Drivers & Utilities, EPSON Scan, SilverFast Ai Studio 8
- OS Required
- 65.6 cm
- 45.8 cm
- 29.2 cm
- 19.6 kg
- 5 °C
- 35 °C
- 10 - 80%
