Epson ET-7750 ink jet printer – A3
Quicklinx: DBXSWS00 Mfr#: C11CG16401CE
This cartridge-free model is designed for printing lots of photos at ultra-low cost. For high-quality results, it uses four dyes and a pigment ink. It's hassle-free to use with an SD card slot, borderless photo printing and dual paper trays. It's also easy to set up, reliable and designed for mess-free refills.
  • Quality A3 photo printing
    This 3-in-1 EcoTank provides an ultra-low-cost solution for high-quality photo printing up to A3, with its ultra-high-capacity ink tanks.
Epson EcoTank ET-7750 - multifunction printer - colour
Multifunction printer
United Kingdom
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 5-ink
Max Printing Speed
Up to 13 ppm (mono) / up to 10 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Max Printing Resolution Class
Scanning
1200 x 2400 dpi
Original Type
Sheets
Media Size
A3 (297 x 420 mm) (max)
Media Type
Envelopes, plain paper, photo paper, printable CD/DVD disc
Standard Media Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB, LAN, USB host, Wi-Fi
AirPrint Enabled
AC 230 V
52.6 cm x 41.5 cm x 16.8 cm
10.5 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty with product registration
Printing Technology
Ink-jet - colour
Display Colour Support
AirPrint Enabled
United Kingdom
Supported Flash Memory
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
360 nozzles (black), 180 nozzles (per colour)
Max Printing Speed
Ink Cartridge Configuration
5 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, photo black
5-ink
Minimum Ink Droplet Size
1.5 pl
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Document & Media Handling
Original Type
Sheets
Max Media Size
A3
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
100 sheets
Input tray - 100 sheets , CD/DVD tray , Bypass tray
Speed Details
Printing: up to 28 ppm - B/W , Printing: up to 28 ppm - colour , Printing: up to 13 ppm - B/W (ISO/IEC 24734) , Printing: up to 10 ppm - colour (ISO/IEC 24734) , Printing: up to 5.5 ppm - B/W duplex (ISO/IEC 24734) , Printing: up to 4.5 ppm - colour duplex (ISO/IEC 24734) , Printing: 20 sec (10 x 15 cm (4"x6")) - photo
1 x USB , 1 x LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
WEP, WPA-PSK, Wi-Fi Direct
Operating System Support
MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, Windows 8.1
AC 230 V
15 Watt
Power Consumption Sleep
1 Watt
Consumables Included
2 x ink tank (black) - up to 14000 pages , 2 x ink tank (cyan) - up to 9000 pages , 2 x ink tank (magenta) - up to 9000 pages , 2 x ink tank (yellow) - up to 9000 pages , 2 x ink tank (photo black) , 1 x maintenance cartridge
ENERGY STAR Certified
Limited warranty - 3 years
52.6 cm
41.5 cm
16.8 cm
10.5 kg
Sound Emission
37 dBA (operating)
DBXS Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £14.99
DBXS Epson Premium Glossy A4 Photo Paper 15 Sheets In Stock £12.40
DBXS Epson Premium Glossy Photo Paper - glossy photo paper - 15 sheet(s) In Stock £12.40
DBXS Epson Premium Glossy Photo Paper - 30 Sheets In Stock £8.99
DBXS Epson Premium Glossy Photo Paper - 100 x 150 mm - 40 sheets In Stock £8.26
DBXS Epson Premium Glossy Photo Paper BOGOF - 100 x 150 mm - 255 g/m2 - 40 sheets (pack of 2 ) In Stock £8.81
DBXS Epson A3 Premium Glossy Photo Paper In Stock £32.43
DBXS Epson Ultra Glossy Photo Paper 10x15 50 Sheets In Stock £10.59
DBXS Epson A4 Glossy Photo Paper 20 Sheets In Stock £9.58
DBXS Epson Glossy Photo Paper 50 Sheets In Stock £8.10
DBXS Epson Glossy Photo Paper 50 Sheets In Stock £6.99
DBXS Epson Glossy Photo Paper 100 Sheets In Stock £8.71
DBXS Epson Glossy Photo Paper 200 Sheets In Stock £31.39
DBXS Epson A4 Glossy Photo Paper 50 Sheets In Stock £18.83
DBXS Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £11.37
DBXS Epson A4 Iron On Transfer Pack 10sht In Stock £13.27
DBXS Epson 106 EcoTank Cyan Ink Bottle In Stock £8.96
DBXS Epson 106 EcoTank Magenta Ink Bottle In Stock £8.96
DBXS Epson 106 EcoTank Photo Black Ink Bottle In Stock £8.96
DBXS Epson 106 EcoTank Yellow Ink Bottle In Stock £8.96
DBXS Epson 105 EcoTank Black Ink Bottle In Stock £13.84
DBXS Epson Matte Paper Heavyweight A4 50 sheets In Stock £11.37
DBXS Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £14.69
DBXS Epson A3 Matte Paper Heavyweight 50 sheets In Stock £29.33
