Epson Epson Expression Premium XP-900 - Multifunction printer - co
Quicklinx: DK71WS00 Mfr#: C11CF54401
Type: Printer / copier / scanner
Functionality: Copier, Printer, Scanner
Output Type: Colour
Wireless Capability: Wireless
Technology: Ink-jet
£125.38 ex VAT
£150.45 inc VAT
A3 photos
Take control and print high-quality photos up to A3 size at home. Why wait around? Produce photographs that exceed lab quality, on demand, with this convenient and fast printer.
Best of both worlds
Create your own photos and crisp, clear text documents with the five-colour Claria Premium dye and pigment ink-set. Photographs will be crystal clear with vibrant colours and deep, rich blacks thanks to the Photo Black ink cartridge.
Mobile printing
Printing photos and documents on the go is easy with the XP-900. Unlock the potential of your smartphone or tablet by downloading the iPrint app to print and scan wirelessly. Make the most of your Facebook photos with the Creative Print app, which allows you to print photos directly from Facebook, create custom greeting cards, turn photos into colouring book templates, and plenty more. In addition, you can email documents and photos directly to the printer from almost anywhere in the world with Epson Email Print .
Easy to use
It's easy to navigate the printer's features via the large 6.8cm LCD screen. Printing photos directly is also simple; just slot in a memory card. There's also the rear speciality-paper feed for printing on to thicker media up to A3, automatic duplex and the capability to print on to suitable CD/DVDs.
  • All-in-one with A3 printing
    A versatile and compact Wi-Fi all-in-one that offers outstanding photos up to A3 size, a large LCD screen, auto duplex, CD and DVD printing.
Epson Expression Premium XP-900 - multifunction printer - colour
Printing Technology
Ink-jet (colour)
Inkjet Technology
Epson Micro Piezo - 5-ink
Max Printing Speed
Up to 28 ppm (mono) / up to 28 ppm (colour)
Max Printing Resolution
Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
Scanning
1200 x 2400 dpi
Original Size
A3 (297 x 420 mm) (max)
Original Type
Sheets
Media Size
Legal (216 x 356 mm), A3 (297 x 420 mm) (max)
Media Type
Envelopes, plain paper, photo paper
Standard Media Capacity
100 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB, USB host, Wi-Fi
AirPrint Enabled
Office Machine Features
Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, red-eye correction, scan to Cloud, Photo Enhance
AC 230 V (50/60Hz)
47.9 cm x 35.6 cm x 14.8 cm
8.3 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Printing Technology
Ink-jet - colour
AirPrint Enabled
Supported Flash Memory
SD Memory Card, USB flash drive, SDHC Memory Card, SDXC Memory Card
Printing
Inkjet Technology
Epson Micro Piezo
Nozzle Configuration
360 nozzles (black), 180 nozzles (per colour)
Max Printing Speed
Ink Cartridge Configuration
5 cartridges (1 each: cyan, magenta, yellow, black, photo balck)
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, photo black
5-ink
Minimum Ink Droplet Size
1.5 pl
Ink Type
Epson Claria Premium Ink
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Document & Media Handling
Max Original Size
A3 (297 x 420 mm)
Original Type
Sheets
Max Media Size
A3
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
100 sheets
Input tray - 100 sheets - A3 (297 x 420 mm) , CD/DVD tray
Speed Details
Printing: up to 28 ppm - B/W , Printing: up to 28 ppm - colour , Printing: up to 14 ppm - B/W (ISO/IEC 24734) , Up to 11 ppm - color (ISO/IEC 24734) , Printing: 12.5 sec (10 x 15 cm (4"x6")) - photo
1 x USB , 1 x USB host
Security Protocols & Features
WEP, WPA-PSK, Wi-Fi Direct
Operating System Support
MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, Windows 8.1, Windows 10
Software Included
EPSON Print CD, Epson Easy Photo Print, Epson Connect
AC 230 V (50/60Hz)
15 Watt
Power Consumption Sleep
1 Watt
Direct Printing Specifications
PictBridge
Consumables Included
1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow) , 1 x Cartridge (photo black)
ENERGY STAR Certified
Limited warranty - 1 year - carry-in
47.9 cm
35.6 cm
14.8 cm
8.3 kg
Sound Emission
37 dBA (operating)
DK71 Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) In Stock £13.08
DK71 Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets In Stock £9.51
DK71 Epson Matte Paper Heavyweight A4 50 sheets In Stock £9.51
DK71 Epson Premium - semi-gloss photo paper - 20 sheets - A4 In Stock £11.89
DK71 Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) In Stock £11.89
Functionality: Printer
Functionality: Scanner
Output Type: Colour
Technology: Ink-jet
Max Print Speed: 28ppm
Brand: Epson
Price Range Ex VAT: 100 - 150
