A3 photos
Take control and print high-quality photos up to A3 size at home. Why wait around? Produce photographs that exceed lab quality, on demand, with this convenient and fast printer.
Best of both worlds
Create your own photos and crisp, clear text documents with the five-colour Claria Premium dye and pigment ink-set. Photographs will be crystal clear with vibrant colours and deep, rich blacks thanks to the Photo Black ink cartridge.
Mobile printing
Printing photos and documents on the go is easy with the XP-900. Unlock the potential of your smartphone or tablet by downloading the iPrint app to print and scan wirelessly. Make the most of your Facebook photos with the Creative Print app, which allows you to print photos directly from Facebook, create custom greeting cards, turn photos into colouring book templates, and plenty more. In addition, you can email documents and photos directly to the printer from almost anywhere in the world with Epson Email Print .
Easy to use
It's easy to navigate the printer's features via the large 6.8cm LCD screen. Printing photos directly is also simple; just slot in a memory card. There's also the rear speciality-paper feed for printing on to thicker media up to A3, automatic duplex and the capability to print on to suitable CD/DVDs.
All-in-one with A3 printing
A versatile and compact Wi-Fi all-in-one that offers outstanding photos up to A3 size, a large LCD screen, auto duplex, CD and DVD printing.
- Epson Expression Premium XP-900 - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- Epson Micro Piezo - 5-ink
- Max Printing Speed
- Up to 28 ppm (mono) / up to 28 ppm (colour)
- Max Printing Resolution
- Up to 5760 x 1440 dpi (mono) / up to 5760 x 1440 dpi (colour)
- Scanning
- 1200 x 2400 dpi
- Original Size
- A3 (297 x 420 mm) (max)
- Original Type
- Sheets
- Media Size
- Legal (216 x 356 mm), A3 (297 x 420 mm) (max)
- Media Type
- Envelopes, plain paper, photo paper
- Standard Media Capacity
- 100 sheets
- Automatic Duplexing
- Yes (printing)
- Connection Availability
- Interface
- USB, USB host, Wi-Fi
- AirPrint Enabled
- Office Machine Features
- Print from memory card, save to memory card, print from USB flash drive, save to USB flash drive, red-eye correction, scan to Cloud, Photo Enhance
- Power
- AC 230 V (50/60Hz)
- 47.9 cm x 35.6 cm x 14.8 cm
- 8.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- 1 year warranty
- Ink-jet - colour
- Interface
- AirPrint Enabled
- Supported Flash Memory
- SD Memory Card, USB flash drive, SDHC Memory Card, SDXC Memory Card
Printing
- Inkjet Technology
- Epson Micro Piezo
- Nozzle Configuration
- 360 nozzles (black), 180 nozzles (per colour)
- Ink Cartridge Configuration
- 5 cartridges (1 each: cyan, magenta, yellow, black, photo balck)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black, photo black
- 5-ink
- Minimum Ink Droplet Size
- 1.5 pl
- Ink Type
- Epson Claria Premium Ink
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
Document & Media Handling
- Max Original Size
- A3 (297 x 420 mm)
- Original Type
- Sheets
- Max Media Size
- A3
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), 100 x 150 mm, 130 x 180 mm, 100 x 148 mm, 90 x 130 mm, 200 x 250 mm, 130 x 200 mm
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C6 (114 x 162 mm)
- 100 sheets
- Input tray - 100 sheets - A3 (297 x 420 mm) , CD/DVD tray
- Speed Details
- Printing: up to 28 ppm - B/W , Printing: up to 28 ppm - colour , Printing: up to 14 ppm - B/W (ISO/IEC 24734) , Up to 11 ppm - color (ISO/IEC 24734) , Printing: 12.5 sec (10 x 15 cm (4"x6")) - photo
- 1 x USB , 1 x USB host
- WEP, WPA-PSK, Wi-Fi Direct
- Operating System Support
- MS Windows XP, MS Windows XP Professional x64 Edition, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.6.8 or later, Windows 8, Windows 8.1, Windows 10
- Software Included
- EPSON Print CD, Epson Easy Photo Print, Epson Connect
- Voltage Required
- 15 Watt
- Power Consumption Sleep
- 1 Watt
- Direct Printing Specifications
- PictBridge
- Consumables Included
- 1 x Cartridge (black) , 1 x Cartridge (cyan) , 1 x Cartridge (magenta) , 1 x Cartridge (yellow) , 1 x Cartridge (photo black)
- ENERGY STAR Certified
- Limited warranty - 1 year - carry-in
- 47.9 cm
- 35.6 cm
- 14.8 cm
- 8.3 kg
- Sound Emission
- 37 dBA (operating)
Epson Double-Sided Matte Paper - Two-sided matte paper - A4 (210 x 297 mm) - 178 g/m2 - 50 sheet(s) | In Stock | £13.33 |
Epson Photo Quality Paper - A4 (210 x 297 mm) - 105 g/m2 - 100 sheets | In Stock | £9.70 |
Epson Matte Paper Heavyweight A4 50 sheets | In Stock | £9.70 |
Epson Premium - semi-gloss photo paper - 20 sheets - A4 | In Stock | £12.12 |
Epson Archival - Matte paper - A4 (210 x 297 mm) - 189 g/m2 - 50 sheet(s) | In Stock | £11.36 |
