Epson ELPSC26 Projector Screen 80" Multi-Aspect 4:3
Quicklinx: 9XR5WS00 Mfr#: V12H002S26
£147.33 ex VAT
£176.79 inc VAT
The Epson multi-aspect screen offers you all-in-one screen solution, which fits all projectors. Thanks to its flexible set-up feature, you can easily adjust the screen to 4:3, 16:9 or 16:10 aspect ratios within seconds. Its exceptional value is complemented by its compact size and portable weight, offering you extra flexibility. The Epson multi-aspect screen is definitely your preferred partner for business or home projection.
  • Projector screen
    When you've invested in a projector, it makes sense to choose a screen that will deliver the vibrant and detailed display offered by your projector. Quick to assemble and adjust, you can set up the screen quickly providing a stress-free experience. Giving you far more flexibility than a fixed TV screen, they're also easy to take apart and stow away.
Epson 65"/74"/80" Multi-aspect - projection screen - 80" (203.2 cm)
Projection screen
Projection Screen Image Diagonal Size
80" (203.2 cm)
Aspect Ratio
16:10 / 16:9 / 4:3
10 kg
Epson EB-1750, 1751, 1760, 1761, 1770, 1771, 1775, 1776, 1840, 1860, 1900, 1920, 1925, 945, 955, 965, 98, S02, S03, S04, S10, S17, S18, S27, S31, S92, U04, U32, W03, W04, W06, W110, W18, W28, W29, W31, W32, X03, X10, X11, X15, X18, X24, X27, X31, x92, EH-TW550, TW5705, TW5825
Projection screen
Image Diagonal Size
80" (203.2 cm)
Aspect Ratio
16:10 / 16:9 / 4:3
10 kg
Epson EB-1750, EB-1751, EB-1760W, EB-1761W, EB-1770W, EB-1771W, EB-1775W, EB-1776W, EB-1840W, EB-1860, EB-1900, EB-1920W, EB-1925W, EB-945H, EB-955WH, EB-965H, EB-98H, EB-S02, EB-S02H, EB-S03, EB-S04, EB-S10, EB-S17, EB-S18, EB-S27, EB-S31, EB-S92, EB-U04, EB-U32, EB-W03, EB-W04, EB-W06, EB-W110, EB-W18, EB-W28, EB-W29, EB-W31, EB-W32, EB-X03, EB-X10, EB-X11, EB-X15, EB-X18, EB-X24, EB-X27, EB-X31, EB-x92, EH-TW550, EH-TW5705, EH-TW5825
