Epson ELP L58 Replacement Lamp
Quicklinx: 7F37WS00 Mfr#: v13h010l58
Type: Projector lamp
Stock Status: Used Stock
£139.79 ex VAT
£167.74 inc VAT
The genuine Epson ELP-LP58 ultra high efficiency (UHE) projector lamp is designed to replace the original genuine Epson projector lamp. This projector lamp is user-replaceable.
Epson ELPLP58 - projector lamp
Projector lamp - E-TORL UHE - 200 Watt
Bulb life cycle
4000 hour(s) (standard mode) / 5000 hour(s) (economic mode)
Epson EB-S10, EB-S9, EB-S92, EB-W10, EB-W9, EB-X10, EB-X9, EB-x92, EX-3200, EX-5200, EX-7200, VS200; PowerLite 1220, 1260, S10+, S9, W10+, X10+
Projector lamp
Lamp
E-TORL UHE
200 Watt
Life Cycle
Epson EB-S10, EB-S9, EB-S92, EB-W10, EB-W9, EB-X10, EB-X9, EB-x92, EX-3200, EX-5200, EX-7200, VS200 , Epson PowerLite 1220, 1260, S10+, S9, W10+, X10+
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 7F37 024563
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £20.06
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Epson
Price Range Ex VAT: 100 - 150
