Bring the movie theater experience home with this HDR-capable, 4K-enhanced projector, utilizing Epson's technology and 3LCD technology.
4K PRO-UHD projector
Bring the movie theatre experience home with this 4K PRO-UHD , HDR-capable projector, utilising Epson's 3LCD technology.
- Epson EH-TW7400 - LCD projector - 3D - LAN - white
- LCD projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- White
- Brightness (White)
- 2400 lumens
- Brightness (Colour)
- 2400 lumens
- Contrast Ratio
- 200000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- UHE 250 Watt
- Bulb life cycle
- Up to 3500 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
- Video Input
- RGB LAN
- Power
- AC 120/230 V (50/60 Hz)
- 355 Watt
- 52 cm x 45 cm x 19.3 cm
- 11.2 kg
- 2-year warranty
- 3D Capable
- Networking
- Ethernet
- Enclosure Colour
- White
Projector
- 2400 lumens
- 2400 lumens
- Contrast Ratio
- Image Size
- 127 cm - 762 cm
- Projection Distance
- 3 m - 6.3 m
- Throw Ratio
- 1.35 - 2.84:1
- Resolution
- Full HD - Full HD (1920 x 1080)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 480 Hz
- Bulb type
- UHE 250 Watt
- Bulb life cycle
- Side-by-Side, Dynamic Mode, 4K Enhancement, Bright Cinema, Cinema Mode, 3D Dynamic Mode, 3D Cinema Mode, 3D depth adjustment
Lens
- Focus Type
- Powered
- Lens Aperture
- F/2.0-3.0
- Zoom Type
- Powered
- Zoom Factor
- 2.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
- Vertical Lens Shift
- 96.3% / 96.3%
- Horizontal Lens Shift
- 47.1% / 47.1%
Video Input
- Analogue video Signal
- RGB
- Video Interfaces
- VGA, HDMI
- LAN and Wireless Image Transferring Protocols
- Wired LAN
- 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type B (management) , 3 x HDMI - 19 pin HDMI Type A , 1 x network - RJ-45 , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management)
- Included Accessories
- Remote control, HDMI cable clamp
- Security Features
- Security Slot Type
- Kensington security slot
- Power Source
- AC
- Voltage Required
- 355 Watt
- Power Consumption Stand by
- 0.2 Watt
- 52 cm
- 45 cm
- 19.3 cm
- 11.2 kg
- Limited warranty - 2 years - carry-in , Limited warranty - lamp - 3 years / 3000 hours
- 5 °C
- 35 °C
- Sound Emission
- 31 dBA
- Sound Emission (Economic Mode)
- 20 dBA
