Epson EH-TW6700 3LCD 3000 Lumens Projector
Quicklinx: FB5GWS00 Mfr#: V11H799041
Sharp, smooth images
Using Epson's 3LCD technology for high brightness and vivid colour, this Full HD projector features high White and Colour Light Output of 3,000 lumens and 70,000:1 dynamic contrast ratio. This technology ensures bright, vivid colours and deep blacks. Frame interpolation and Detail Enhancement provide sharper and smoother motion pictures and great detail, for greater clarity, and the EH-TW6700 can also convert standard 2D video into 3D.
Enjoy the big-screen experience with easy set-up
Sit back and immerse yourself in the experience from the very start with our easy to install, simple to use projector, which can be placed almost anywhere. With this model boasting a 1.6x optical zoom, vertical ±60% and horizontal ±24% keystone correction, superbly aligned images can be achieved effortlessly. Maintenance is also kept to a minimum with the EH-TW6700. Thanks to the incredibly long lamp life, you can watch a movie every day on the big screen for the next seven years .
  • Home cinema projector
    Experience the awe-inspiring feel of the big screen at home with this Full HD 2D & 3D projector with 3LCD technology for high-quality images.
Epson EH-TW6700 - 3LCD projector - 3D - white
3LCD projector - 1080p
3D Capable
Yes (3D glasses sold separately)
White
Built-in Devices
Stereo speakers
Brightness (White)
3000 lumens
Brightness (Colour)
3000 lumens
Contrast Ratio
70000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Lens Shift Direction
Horizontal, vertical
Bulb type
250 Watt
Bulb life cycle
Up to 3500 hours - normal mode , Up to 5000 hours - economic mode
Video Input
RGB
Speakers
Speaker(s) - integrated
AC 120/230 V (50 - 60 Hz)
364 Watt
41 cm x 30.4 cm x 15.7 cm
6.9 kg
3D Capable
Built-in Devices
Stereo speakers
Enclosure Colour
White
Projector
Brightness (White)
3000 lumens
Brightness (Colour)
3000 lumens
Contrast Ratio
70000:1 (dynamic)
Image Size
76 cm - 762 cm
Projection Distance
2.95 m - 4.8 m
Throw Ratio
1.32 - 2.15:1
Resolution
Full HD - Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
Bulb type
250 Watt
Bulb life cycle
EPSON 3LCD technology, Dynamic Mode, Theater Mode, MHL compliance
Lens
Focus Type
Manual
Lens Aperture
F/1.51-1.99
Zoom Type
Manual
Zoom Factor
1.6x
Keystone Correction Direction
Vertical Keystone Correction
-30 / +30
Horizontal Keystone Correction
-30 / +30
Lens Shift Type
Manual
Vertical Lens Shift
60% / 60%
Horizontal Lens Shift
24% / 24%
Video Input
Analogue video Signal
RGB
Video Interfaces
VGA, HDMI, MHL
Speakers
Integrated
Sound Output Mode
Stereo
Output Power / Channel
20 Watt
Speakers
2 x right / left channel
1 x HDMI - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin D-Sub (DB-15) , 1 x USB 2.0 - 4 pin USB Type A , 1 x USB 2.0 - 4 pin mini-USB Type B , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x audio line-out
Wireless remote control
Security Features
Power Source
AC
364 Watt
Power Consumption Stand by
0.4 Watt
41 cm
30.4 cm
15.7 cm
6.9 kg
Limited warranty - 2 years - carry-in , Limited warranty - lamp - 3 years / 3000 hours
5 °C
35 °C
20 - 80%
Sound Emission
32 dBA
24 dBA
FB5G Epson Wireless Adaptor LAN B/G/N In Stock £101.99
