Sharp and bright images
This Full HD projector uses 3LCD technology and 2,500 lumens brightness, with equally high White and Colour Light Output, to ensure vivid colours with no rainbow effect, while the 70,000:1 contrast ratio means deep blacks and highly detailed images in dark scenes.
Easy positioning
With wide vertical and horizontal lens shift, it's easy to position the EH-TW6600 off-centre to a screen, creating a precisely-sized image, with no distortion or stretching. Combined with a 1.6x zoom lens and a compact design, it makes it incredibility simple to set up in any environment. Integrated 20W stereo speakers free you to connect to any external system, while all audio can easily be sent to a sound system using dedicated outputs.
Advanced imaging technology
Able to convert 2D video to 3D for maximum versatility, the EH-TW6600 includes seven colour modes – including two specially for 3D – and a pair of RF 3D glasses . By sensing the ambiaent light levels, the auto colour optimiser can automatically identify the best setting, and Epson's enhanced Super Resolution ensures both 2D and 3D video looks as sharp and crisp as possible.
Home cinema projector
A Full HD 2D & 3D projector that delivers lots for your money, with 3LCD technology for exceptional, high-contrast images.
- Epson EH-TW6600 - 3LCD projector - 3D
- 3LCD projector - 1080p
- 3D Capable
- Yes (3D glasses included)
- Built-in Devices
- Stereo speakers, 0.61-inch LCD
- Brightness (White)
- 2500 lumens
- Brightness (Colour)
- 2500 lumens
- Contrast Ratio
- 70000:1 (dynamic)
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Lens Shift Direction
- Horizontal, vertical
- Bulb type
- UHE 230 Watt
- Video Input
- RGB, composite video, component video
- Speakers
- Speaker(s) - integrated
- 366 Watt
- 41 cm x 30.4 cm x 15.7 cm
- 6.8 kg
- 2-year warranty
- 3D Capable
- Built-in Devices
Projector
- 2500 lumens
- 2500 lumens
- Contrast Ratio
- 70000:1 (dynamic)
- Image Size
- 76 cm - 762 cm
- Projection Distance
- 0.87 m - 14.5 m
- Throw Ratio
- 1.32 - 2.15:1
- Resolution
- Full HD - Full HD (1920 x 1080)
- 16:9
- Colour Support
- Bulb type
- UHE 230 Watt
- 16:9 aspect ratio support, Split Screen, Dynamic Mode
Lens
- Focus Type
- Manual
- Lens Aperture
- F/1.51-1.99
- Zoom Factor
- 1.6x
- Keystone Correction Direction
- Vertical Keystone Correction
- -30 / +30
- Horizontal Keystone Correction
- -30 / +30
- Vertical Lens Shift
- 60% / 60%
- Horizontal Lens Shift
- 24% / 24%
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, MHL
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 10 Watt
- Speakers
- 2 x right / left channel
- 1 x composite video input - RCA , 1 x component video input - RCA x 3 , 1 x HDMI - 19 pin HDMI Type A , 1 x component video / RGB input - 15 pin D-Sub (DB-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x USB 2.0 - 4 pin USB Type A , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A
- Included Accessories
- WirelessHD Transmitter Set, wireless remote control
- Security Features
- 366 Watt
- Power Consumption Stand by
- 0.43 Watt
- 41 cm
- 30.4 cm
- 15.7 cm
- 6.8 kg
- Limited warranty - 2 years , Limited warranty - lamp - 1 year / 750 hours
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 24 dB
